603,965 active members*
2,529 visitors online*
Results 1 to 5 of 5
    Oct 2006
    4
    Vibrating Table design help needed
    Hello....I am making a vibrating table to polish marble.
    Would appreciate input on the mechanism to make it vibrate.
    So far.....steel pan....4' x 2' mounted on 4 heavy duty rubber isolation mounts.
    Idea 1....4 foot long HORIZOTAL shaft in 4 pillow blocks...and 2 cam lobes running along the side of the pan....pushing it sideways.
    Idea 2 VERTICAL shaft underneath with a cam lobe on the end....spinning around and hitting a metal bar, welded to the bottom of the pan...pushing it sideways
    Idea 3 Vertical shaft underneath with a cam lob spinning around inside a ring....welded to the bottom of the pan....pushing out in 360 degrees....
    Idea 4 should I do something with an eccentric? if so what?
    Would appreciate any input...
    Thanks, Leland
    Hi Leland,
    I've done this on a smaller scale. I needed a cheap, but larger than
    normal vibratory bowl for polishing jewelry parts. I used a 18" pan for
    changing your car oil and an $11.99 walmart fan motor.
    The motor was mounted in a wooden ring with 4 springs around it.
    Different thicknesses and lengths of springs were tried. the bowl
    was attached to the top of the springs on a second wood ring...
    cut out with a simple circle cutting router attachment.
    I just bolted a piece of brass to the motor shaft to make it wobble
    like an SOB....A few experiments with the springs(they're pretty heavy
    duty...from ACE hardware) and it worked like an industrial charm.
    I still have it. I ran it for DAYS at a time for about 12 years. I was
    always prepared to upgrade the motor to a regular 1/2 horse or so,
    because I was so reliant on the thing. But it just kept working.
    I'll have to get you some pictures. It's a sorry looking thing, but it's
    unstoppable. That on an adjusted scale would work great. I wanted
    to do the same thing you're talking about to polish flat surfaces, but
    I just haven't gotten to it yet. CNC got in the way
    John
    Mar 2004
    1661
    Check this one out, a simple but very nice solution:
    http://www.cnczone.com/forums/showpo...postcount=2079
    Regards,
    Sven
    Nov 2006
    251
    Idea 3 sounds good with the 4 rubber mounts ,you may like to use a bearing on the end of that vertical cam to give it some life and reduce some friction.
    Sep 2007
    10
    I built a 48" x 96" vibrating table for casting concrete 10 years ago and still use it. Check out Vibco for electric or pnuematic vibrators, and you'll definitely want to use air bags to isolate the table from the base, unless you want the whole house shaking loose. I got mine from Goodyear. If you want more details let me know.
    Burt
  1. There is this faint vibrating/hissing/humming feels to my stepper motor. Why?
    By alexccmeister in forum Automation Technology Products
    Last Post: 05-21-2007, 01:45 AM
  2. XY table design basics, linear ways to table size ratio?
    By Konstantin in forum Mechanical Calculations/Engineering Design
    Last Post: 03-13-2007, 06:21 PM
  3. Looking for input on CNC table design
    By yellow73bb in forum Waterjet General Topics
    Last Post: 10-16-2006, 05:20 PM
  4. new table design question
    By KTP in forum DIY CNC Router Table Machines
    Last Post: 07-21-2006, 10:21 PM
  5. My plasma table design
    By m_c in forum Waterjet General Topics
    Last Post: 07-24-2004, 07:01 PM
