587,357 active members*
3,411 visitors online*
IndustryArena Forum > MetalWorking Machines > Knee Vertical Mills > vibration problem with new machine
    Jun 2009
    43
    I purchased a new gmc 10 x 54 and between 2759-3000 rpm I am getting a small vibration in the spindle head. The model is a varible speed unit. Any other rpm range the vibration seems to disapate. I do not have the draw bar installed yet because it is bent and the machine supplier is sendind a new one. Could running the machine without a drawbar cause this? When it vibrates you can feel it in the movements in the table's y axis. Should I check the varible speed drive belt for debre stuck on a pully or any other visual inspections. Thanks for any replies
    Nov 2007
    How did it turn out with the vibration problem?
    I'm thinking of getting the same machine next month.
    I can't find anyone around with one and reviews are hard to find. I would really appreciate any info you want to share about the GMC.
    Jun 2009
    43
    The vibration went away. I think it was the seam on the drive belt. It stopped after the belt wore in. I am very happy with the machine. It has good quality for the price.
  1. machine problem or software problem?
    By bcnc in forum Syil Products
    Last Post: 10-26-2009, 03:51 PM
  2. vibration problem
    By greko in forum Daewoo/Doosan
    Last Post: 10-21-2008, 09:49 AM
  3. Oerlikon B24 grinding machine with vibration in Z axis
    By cervanp in forum CNC Machining Centers
    Last Post: 08-28-2008, 08:02 AM
  4. Problem with Solsylva DIY Machine
    By mlammert in forum DIY CNC Router Table Machines
    Last Post: 07-09-2008, 12:11 PM
  5. L297 l298 vibration sound problem
    By ez-cnc.com in forum Stepper Motors / Drives
    Last Post: 04-30-2006, 01:29 AM
