Finally after 2 years I circled back around to this. Made this up from some scrap MIC-6 plate that I got a hold of. The odd length is me just trying to avoid some of the dinged up areas and some holes that had been drilled into it. I wish I had made it a bit wider in the Y direction. Wasn't thinking of just the extra clamping space. I do have another plate so I can refine again if I find anything too lacking in this plate. It's 44 3/8-16 holes on 1" centers. The top sits on a 9" x 3.75" x 1.425" block of 6161 to hopefully keep the rigidity up and let me use a plate larger than I could clamp in the jaws. Surfaced the plate with my 2.5" facemill. Wish I had the 4" or 5" for this job but it worked alright. The surface measured out to 0.0005 front to back and dead flat over the X travel. They Y tram never is perfect so there are a few tenths of rise over each pass but I doubt that will be the limiting factor in my work.
I like this pretty well I think and looking a few past parts I have been working on I think I woould have liked to have it when I was doing them.
Next step will be to create some holes for dowel pins. My plan is to create it in CAM but edit it to always approach the holes from left to right in each row working top to bottom. That should allow it too take up any backlash to keep the positions. Spot drill, pilot dril, drill to 0.007 to 0.010 under size then ream to a close fit for the pins. I don't plan to use the pins for absolute positioning but instead just to align the parts to repeat to the work peice zero each time on multiple parts. I'm planning to use 3/16" pins for that, maybe 1/4" havent decided.
I have set screws coming to plug the holes to keep them from packing up with chips.
CNC: Making incorrect parts and breaking stuff, faster and with greater precision.
