603,850 active members*
5,050 visitors online*
IndustryArena Forum > CAM Software > Surfcam > Viewing files created in NX5
Results 1 to 4 of 4
    Feb 2009
    3
    Hello, I am an undergrad research assistant at a major engineering university. Part of my research requires me to create drawings to send to the guys in the machine shop so they can machine the parts we need for our experiment. I am using NX5 to create 3-D solid models of the test parts, then using NX5's drafting application to create draft drawings and saving these as .DWG files. However, when I send them to the machine shop, where they are using Surfcam, the files are all messed up, with the various views messed up or missing, extra junk cluttering up the screen, too many layers, etc etc. In short, Surfcam doesn't like NX5. I have tried various methods to get around this bug, but to no avail. My DWGs look fine in NX5 and AutoCAD 2007, its just Surfcam that doesn't like them. Has anybody else heard of this problem before, or possibly know of a solution? I can email you the files if you like. Any help would be greatly appreciated.
    May 2007
    71
    Save your UG-NX file to be X_T parasolid file and send to them.
    Nov 2004
    166
    Quote Originally Posted by sinderal View Post
    Exactly. This is what I used when I ran Surfcam. I think most folks will tell you that parasolids give you the best translated models.
    Hey, why's it going over there?!!
    Feb 2009
    3
    Thank you. I'll try that and see if that works for them. I've exhausted just about every other option, and was getting ready to start boning up on AutoCAD and use that instead of NX5. Hopefully the parasolids will work.
  1. My machine created art
    By Chill_Factor in forum Machine Created Art
    Last Post: 12-11-2008, 06:03 PM
  2. I need help with drawings created from a part.
    By CNCWNTTOBE in forum Uncategorised CAD Discussion
    Last Post: 11-13-2008, 04:21 PM
  3. Has anyone created your own digitizing program?
    By jacep in forum Benchtop Machines
    Last Post: 06-12-2008, 04:39 PM
  4. MCA (Machine Created Art)
    By j m in forum Machine Created Art
    Last Post: 08-27-2007, 01:44 PM
  5. viewing .dxf files Linux
    By Breaker in forum OpenSource Software
    Last Post: 10-01-2006, 11:14 PM
