It seems like all I can do is wait. I am waiting for my timing pulleys and belts, and my metering valves for the lube system. The big wait is to solve my motor drive problem. I want to make sure the motors and encoders I purchased are going to work before I go through all the trouble of making mounts for them. I have spent 15 hours over the last week trying to get my Gecko 320 to run my motors, plus almost 3 hours on the phone with Mariss over the course of 4 phone calls.
At this point I have ferrites on the AC power, DC power, and +5V power for the breakout board. I have the 470uF cap on the motor input, shielded 22 gage cable running to the encoder (I tried a cat 5e cable as well). All three motors behave the same, no matter how I set the pots on the drive. They seem to be randomly hunting for position and when I command a rotation, they sound like they have rocks in the bearings. The motors have run for over 24 hours since installing new brushes, they look fully seated. I have a clean signal from the break out board, 0V to 5V. I have a perfect signal from the encoder on both channel A and B (I ran the motor from a separate power supply while monitoring the channels). The motor is grounded; there is a shielded power cable to the motor. The encoder cable is grounded on only one end, the drive end. I changed the printer cable. The printer cable, motor power cable and encoder cable are separated by at least 1' until they get to the drive. I have tried several motor tuning combinations in Mach 3. I tried feeding the drive with a function generator. The only thing I have not changed is the drive. I ordered a couple more. I will try them when they get here.
I sent the drive I have back to Gecko for evaluation. I hope it is the drive because I am at a loss as to what else could be the problem.
Vince
