603,365 active members*
3,738 visitors online*
    Nov 2020
    Viper V60 troubles
    I am building a mill using V60 drives and Bx7. They repeatedly send a reset to Mach3 but the drives show no fault led. Larken says I need an opto coupler in the fault cct to connect the two boards.
    Which two boards? Why do the pdf manuals not show an opto coupler in their drawings? Any help available?
    Feb 2007
    972
    Re: Viper V60 troubles
    Its because you probably have noise between the drive and bob so try adding an RC filter in the connection. Try adding a 200 ohm resistor and a 100uf Cap. I'm helped you alot but when you start getting rude, im not interested.
    Larry
    Manufacturer of CNC routers and Viper Servo Drives
    www.LarkenCNC.com and www.Viperservo.com
  1. Viper 20/25 VTL
    By Dbear in forum Tutorials
    Last Post: 02-12-2015, 03:25 AM
  2. Viper 250 ??????
    By jeep534 in forum Viper Servo drives
    Last Post: 04-08-2012, 07:58 PM
  3. st 20 troubles
    By laamar in forum Haas Lathes
    Last Post: 02-03-2012, 05:11 PM
  4. air troubles
    By wadetool in forum Haas Mills
    Last Post: 02-19-2007, 10:30 PM
