603,826 active members*
3,502 visitors online*
    Apr 2006
    19
    Visual Quick Code on TL4
    We have a new TL-4 and we are trying to use VQC to generate programs for now. When trying to generate program for Two diameters with two outside corner radius the code put out had G42 and G3 for the outside corner on the nearside, tool on the left. This seems wrong for a Toolroom Lathe, It seems like it should be G41 and G2. The intuitive programming works but is limited.
    Thanks for any insight
    chris
    Nov 2007
    1704
    Welcome to the world of toolroom lathes. The machining centers have the cutters on the backside of the part. All the programming examples in the book are from that point of view.
    The TL series also programs from that point of view, though it seems upside-down to us. Yeah, I know: confusing. But if the IPS screen or the VQC template built it, it's probably right. G02/G03 directions are from the POV of being on the back side of the part.
    Greg
    Apr 2006
    19
    Ok I see everything gets programmed upside down and backwards
    that should be fun to keep straight in my head.
    Thanks for your help
    Chris
  1. Haas Visual Quick Code (VQC)
    By ethal68 in forum Haas Visual Quick Code
    Last Post: 02-10-2014, 04:51 AM
  2. Quick Code, Visual Quick Code
    By 1ctoolfool in forum Haas Mills
    Last Post: 09-17-2006, 04:46 PM
  3. Need help with VISUAL MILL
    By replicapro in forum Visual Mill
    Last Post: 06-18-2006, 04:06 PM
  4. Haas visual quick code
    By GENMACH in forum Haas Visual Quick Code
    Last Post: 11-16-2005, 08:07 PM
