587,853 active members*
3,504 visitors online*
IndustryArena Forum > MetalWorking Machines > Hitachi Seikis > VK45 CRT doesn't come on. Please help!
Results 1 to 5 of 5
    Jun 2010
    5
    Hi All,
    Have a Hitachi Seiki VK45 with a seicos m2. CRT will not come on at power on. Can see a slight orange light at back of CRT tube but nothing on the screen and hydraulics and servos will not start. Ideas?
    Dec 2009
    546
    Re: VK45 CRT doesn't come on. Please help!
    When you turn on the control does it fire up - I know you cant see anything on the control screen but look at the control rack and confirm that the lights on the cards are on/ blinking as normal
    john
    Jun 2010
    5
    Quote Originally Posted by shas595 View Post
    john
    Yes. The servo LEDs are all green. I have no lights on the front card in the rack, but I'm not sure if there are any. Fanuc and Yaskawa guy...not very familiar with the seicos controls.
    Dec 2009
    546
    On the rack there will be boards that should have lights. If you aren't seeing any on any of the boards I'm guessing the control isn't firing up - likely the Power supply. Take another good look around the boards, there are stacks of led's on the long edges of them, you should see something if it does in fact fire up. Also when you power on the control the lights behind the buttons on the panel should come on to indicate the control turned on. Check these items out and let me know
    John
    Jun 2010
    5
    I have no lights on the boards. Also, I dug a little deeper and found what I believe is the power supply (HS-01). It has terminals all the way across the top. All voltages are good except the 24v terminals. these are zero and there are two red LEDs lit on the board. LED2A and LED2B.
  1. Direct Tapping on VK45
    By firstreal in forum Hitachi Seikis
    Last Post: 02-22-2017, 01:49 AM
  2. 4th axis on VK45-2
    By evidence_87 in forum Hitachi Seikis
    Last Post: 09-29-2015, 06:38 PM
  3. Hitachi Seiki vk45
    By davesnd in forum Mori Seiki Mills
    Last Post: 12-02-2010, 05:47 PM
  4. hitachi vk45?
    By mkehler in forum MetalWork Discussion
    Last Post: 08-11-2010, 06:39 PM
  5. Hitachi Seicos VK45
    By buck585 in forum Uncategorised MetalWorking Machines
    Last Post: 08-12-2009, 10:37 PM
