587,245 active members*
3,168 visitors online*
IndustryArena Forum > CAM Software > Visual Mill > VM 6 - Posting in G41 & G42 on 2 1/2 axis
Results 1 to 5 of 5
    Feb 2008
    547
    How do you get it to post using cutter comp. ??
    Steve
    Jan 2004
    3154
    I never use cutter comp so I am not perfectly sure but It should be as simple as editing your post processor and turning cutter comp output on.
    That is what I would do, I have extensively edited all my post processors.
    www.integratedmechanical.ca
    Feb 2008
    547
    Smile Hi Darebee...
    I have always used cutter comp on 2 1/2 axis work, mainly because the work I've done required very high tolerences and it is the best way to tune the program. I most often have used the diameter or radius of the tool, varying the number as needed to get the dimn. with the program definded to the print dimn. Maybe I'm just old school.
    I have heard of using a "0" call out as the offset, running the cutter path in its programmed offset path with the g41 or g42 callouts and if the, need arises, use a minus or plus as necessary to correct cut.
    In the the old 2 1/2 axis CAM I have, it has this option so I assume that VM had it but I have not as yet found it.
    Steve
    Jan 2004
    3154
    I haven't looked at the MecSoft forum today but I suggest you add a copy of your last post there. MecSoft tech can/will answer that.
    I agree that tool offsets are needed for "run from control" production work.
    I do 1-offs and find it easier quicker (for me) to bump my stock +/- in VM and resend the MOP.
    With 1-offs I typically run the MOPs as I make them and program the next toolpath while the last is running.
    Considering my situation I have never bothered to experiment with cutter comps to train myself in their proper use - sorry but I am ignorant ;-)
    Feb 2008
    547
    Thanks Darebee...
    I did post on the MecSoft also. When I understand it all... I'll write to you the details. You may find it something you will like to use. Even for one off's it can be very time saving.
    Steve
    Added: The MecSoft's response was an excellent explaination of how to add and when you would want to use cutter comp.
    Steve
  1. About posting?
    By Netjams in forum DIY CNC Router Table Machines
    Last Post: 04-13-2006, 01:55 AM
  2. RFQ Posting
    By LFJ in forum Employment Opportunity
    Last Post: 08-13-2005, 09:31 PM
  3. Posting RFQ
    By cncadmin in forum RFQ (Request for Quote)
    Last Post: 11-04-2004, 05:57 AM
