603,936 active members*
2,251 visitors online*
Results 1 to 4 of 4
    Oct 2004
    11
    VM Basic Demo
    Is there any way to specify no machine zones around a part in this software. I don't want the cutter to go more than its diameter around the side of the part when profiling. Can I import in a custom stock size the is not square and have the software not profile all the stock. How would you work around clamps etc. Thanks
    Jan 2004
    61
    They refer to that as regions. Check out the machining regions section of the help file and they explain them fairly well. Kinda funky but they work.
    Jan 2004
    3154
    It would be different for both 2.5 or 3d. Which are you asking about?
    Oct 2004
    11
    I'm working with 3d.
  1. newbie Quest. Basic Static Load on Linear Bearing Block kNewton ?
    By Calico in forum Linear and Rotary Motion
    Last Post: 06-28-2007, 12:10 AM
  2. OneCNC XR Online Demo
    By JavaDog in forum OneCNC
    Last Post: 08-12-2005, 04:25 AM
  3. CAD CAM Demo strategy questions?
    By Idle hands in forum Uncategorised CAM Discussion
    Last Post: 05-24-2005, 07:45 PM
  4. Demo?
    By DAB_Design in forum CamSoft Products
    Last Post: 04-11-2005, 05:09 PM
  5. V19 Demo Problems & Questions.
    By SamLS in forum BobCad-Cam
    Last Post: 10-28-2004, 05:03 PM
