Need to life the Z axis on a machine that is no longer powered. The Z axis motor is removed. Milltronics tells me they lift it with a hoist and the leadscrew freely spins. Need to move the blocking from under the spindle to under the carriage for a unit move. I had planned to make a part so I could drive the screw with a 1/2" drive ratchet wrench or similar but apparently I could just jack up the carriage with a jack on the table? The table is about 2/3 of the way back to the column. Have read it should be all the way back but not sure that is necessary. If that needs to be moved I can't support the z axis with the table during the table move.
