587,751 active members*
3,041 visitors online*
IndustryArena Forum > MetalWorking Machines > Tree > VMC 1050 won't move any axes
Results 1 to 20 of 20
    Jan 2011
    We received a 1993 Tree VMC-1050 from a local company, donated to our high school shop. The machine worked fine prior to us receiving it (I verified) but once it was delivered, we had to have a bunch of breakers switched to be CSA certified for safety reasons (mandatory for ESA). All of the work was completed, and now I cannot get the machine to move any axis in jog mode to begin to reference the machine. Myself and the electrician have been over the electrical a bunch of times and can't seem to figure it out. The only fault message I have on the screen is Axes need to be referenced. The procedure I have used so far has been this:
    1. Turn on power
    2. Press Reset and then pressed start button
    3. Select JOG from menu and 1 or 2 for slow or medium continuous jog
    4. Have tried to toggle X, Y & Z axes + and - directions, and all instances give me the same issue. Nothing moves and the control gives me the error message blinking screen. When I go to the fault screen, all that is on there is Axes need to be referenced. ANY IDEAS?? I want to get this thing up and running! Thanks for any help.
    Oct 2008
    26
    manualy push the home switches to see if that clears the error code ... if it does re-home the machine ... make sure you aren't on a limit switch
    Feb 2009
    6028
    The dreaded 1050. Most likely cause is the magazine (tool drum) in not in the rear or home position.
    Second is no air pressure.
    Did you here the machine kick on when you hit start. Should hear contactors latch in. If you didn't, an axis may be on a limit. there are small "doors" you put a long wrench in to and turn the axis off the limit with the wrench.
    Oct 2008
    106
    I think you should look into the ATC home position signal, if the ATC home position not made than all three axis can't be move
    Ahn Vuong
    Jan 2011
    What is the ATC home signal?
    Oct 2008
    106
    It is an automatic tool changer home position
    is your VMC with ATC?
    Ahn Vuong
    Feb 2009
    6028
    Quote Originally Posted by puds View Post
    Again, did you here it power up when you pushed start? The only ATC home is the magazine in the back position. Tree had changed the proms on most of the machines to automatically drive the magazine home once you hit start on power up. If not, you need to manually activate the air solenoids to bring it back. They are right above the actual tool magazine, very easy to get to.
    May 2009
    104
    Before powering up open the left side door and manually cycle the the little white lever 90 degrees and turn it back. There are two "levers" above the magazine on the pneumatic assembly.
    Cycle the upper one.
    The magazine should "clunk" back to home position.
    Power up main power. Power on control. power on again(energizes servos).
    You should be good to go.
    Also check way lube level- machine won't budge when low.
    Wont budge if you power up overtraveled either.
    Jan 2011
    Tried/checked all things and still the same. Machine powers up (latches) on start button push, tried cycling the pneumatic valves for the tool changer cylinder and still nothing. Still the same two errors:
    1. Axes need to be referenced
    2. Magazine # 1 not referenced
    HELP!
    Feb 2009
    6028
    Try going to the jog page, going to ref return, then hit cycle start. That should pull the ATC back, start the axis homing sequence, then the magazine sequence. If you here it latch on, it's not in overtravel.
    Jan 2011
    Tried it and as soon as I hit cycle start, it flashed the error screen and showed me the same two faults again. The tool changer does appear to be all the way back and the switch is activated on the top of the unit (roller style limit switch).
    Feb 2009
    6028
    Is the feedrate overide knob turned up ?
    Jan 2011
    Will check it and try again.
    Jan 2011
    Tried all suggestions, still nothing. Anybody have anything else I should check???
    Apr 2009
    24
    If you are against the limit switches nothing will move. Go into reference mode, push and hold reset, and then move away from limits. Release and press reset for each axis.
    Jun 2004
    42
    Puds,
    This might be stupid but you never know.
    When I read your first post you said: 1. press reset 2. press start then jog
    On some machines in order to shut down the servos you push the emergency stop button. So the order should be. 1. Reset emergency stop button 2. press reset then jog.
    Hope it is that simple.
  17. #17
    Jul 2008
    3
    1993 TREE VMC 1060
    Quote Originally Posted by maz43 View Post
    this will be the same process when you get alarms:
    -carrusel drive not powered up
    -carrusel not reference
    -carrusel alarm
    also with this alarms I can move the axes and reference the machine
    but not turning the spindle on or oriented, this is the reason or maybe something that Iam doing wrong, because this is the first time that I run this
    machines and control.
  18. #18
    Jul 2008
    3
    What is the process when you get this alarms?
    -carrusel alarm
  19. #19
    Jul 2011
    Hey puds,
    where in Canada are you located, I may be able to help if your nearby.
    I spent alot of time fixing one of these machines.
  20. #20
    Jul 2010
    492
    on my vmc 840, i have to hit the yellow switch on the back of the air switch mounted on the carosel if its out a little bit. that sucks it back in to zero, and then allows me to move the axis's and then to reference zero and cycle start
  1. Replies: 6
    Last Post: 03-14-2011, 09:41 PM
  2. MDI SECUENCE TO MOVE THE AXES
    By atlantic23 in forum Fadal
    Last Post: 10-15-2009, 06:03 AM
  3. GE 1050 control
    By bartL in forum Hardinge Lathes
    Last Post: 12-22-2008, 07:37 PM
  4. Ge 1050 -need help
    By JR1050 in forum DNC Problems and Solutions
    Last Post: 02-25-2007, 02:14 AM
  5. 1050 tree zps vmc
    By Treeves in forum Tree
    Last Post: 08-30-2006, 12:13 PM
