588,069 active members*
4,973 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > VMC-15: Spindle Would Not Stop !
Results 1 to 9 of 9
    Sep 2005
    17
    HI ! My VMC-15 did an odd thing tonight. The spindle just took it's sweet time winding down without braking . The message is--EMERGENCY STOP-TAKE APPROPRIATE ACTION SPINDLE WOULD NOT STOP
    Is the therm-resistor thing usually the culprit in this case? how do you check it ?
    Thanks !
    Dec 2003
    24220
    The spindle control is MTB dependant, many will drop all power when an emergency stop is issued, this does not allow a controlled stop of the spindle through the Sp Drive, so the motor just coasts to a stop.
    The thermal dectection is usually a thermal switch buried in the Motor windings or case and should normally read a closed condition, it will open circuit when exposed to a certain heat level.
    A resistance meter with confirm the status.
    Al.
    Albert E.
    Sep 2005
    17
    is it just a matter of pulling the spindle motor cover off and checking the wires with a multimeter. Or is there a way to test it from inside the elecrical panels?
    Dec 2003
    24220
    I am not that familiar with that particular machine, but commonly by taking the spindle cover off , you should be able to identify two small wires that hopefully are marked, if you have the schematics it should help.
    The motor may have MS/Cannon connectors, in that case you will need to identify the pins.
    Use a multimeter ohms range to check.
    They probabally come back to the panel, this is where you need the machine prints.
    Al.
    Albert E.
    Sep 2005
    17
    I pulled the cover off the motor, was pretty dirty but the fan was running fine. I see what I think is the encoder on top but that is the only wire aside from the fan that I see coming out. I disconnected the regen resistor- 13ohm 1100 watt. I checked it for continuity but got nothing. I think it must be burned out, unless I am not using the multimeter correctly, I am a machinist not an electrician.
    Dec 2003
    24220
    Its a pretty straight forward test, at 13 ohms it will read low on any resistance scale.
    At 1.1kw the resistor should show signs of over heat or a possible fused open point on the body if it has blown.
    Make sure the meter leads have a good connection on the terminals.
    Al.
    Albert E.
    Jan 2005
    16
    I had a similar experience with a 15Xt. We called uptimecnc.com
    they were great, helpful, fixed over the phone and no charge. Just did'nt remember what the issue was. It had nothing to do with a dirty cover though.
    Sep 2005
    17
    It was the Regenerative resistor, I checked it and zero continuity and nothing showed for ohms which should have been 13 ohms. Will order a new one from Uptimecnc or Fadalcnc.
    Jan 2005
    16
    I think it was the choke (regen). Good luck
  1. Home Made internal spindle stop!
    By widgitmaster in forum Mini Lathe
    Last Post: 08-13-2016, 10:46 PM
  2. spindle will not stop fadal 4020
    By choppermex in forum Fadal
    Last Post: 06-17-2016, 09:59 AM
  3. Spindle Motor Stop
    By rweatherly in forum Mach Software (ArtSoft software)
    Last Post: 11-25-2006, 05:28 PM
  4. Fanuc 0 M - Spindle Stop
    By Uncle Buck in forum Fanuc
    Last Post: 07-01-2006, 12:18 AM
