587,215 active members*
3,096 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > VMC 4020....STOP BEFORE FINISH THE JOB
Results 1 to 16 of 16
    Apr 2016
    39
    MY VMC 4020..stops before finish the program....the red led of oil pressure is on,but dont need oil
    i reset the red sw on the control board and still working..but after that stops again,somebody knew somting
    Jan 2015
    417
    Re: VMC 4020....STOP BEFORE FINISH THE JOB
    Is it saying waylube is low on the screen? If it's an older machine you have waylube pump and spindle mist oil luber. Waylube will stop machine before it's empty.
    Apr 2016
    39
    Quote Originally Posted by rodney247 View Post
    NO....... the screem show me a axis fault,,,i watch the red led on the control valves board,i reset and work again...but i losse all mi job
    Jan 2015
    417
    Does it the machine go into axis fault at the same place during the program? if in Enter Next Command type SU <enter> it will process program should end at bottom of screen X Y Z
    Jan 2015
    417
    when you say you reset. Are you saying that you do that by pressing the JOG button to reset? Or are you turning the machine off and doing a CS?
    Apr 2016
    39
    no,i go back the machine and push the red switch on the valve control card,(a 4x10 inches,that control the air,oil pressure etc)have a led for each action)
    the OL red led,comes when the machine stops,i reset it and work again as i told you,but i loose all mi job...
    Mar 2008
    683
    Double check all the connectors. It sounds to me like something is just loose. Mine did the exact same thing and there was just a loose cable to the axis control board.
    Do you HAVE an A axis?
    Apr 2016
    39
    Quote Originally Posted by warrenb View Post
    no,but i check all,and look like the oil valve is not working good,becouse i put a jumper and work(is just a switch) but i dont know why stops in the middle of the job
    Mar 2008
    683
    The oil valve is on a timer. It will turn on every 10 minutes or so.
    Can you send the g code?
    Have you ran the part before?
    What year is this Machine?
    Which axis fault? X, Y, A (4th axis) or Z ?
    Can you run other parts?
    Do you have to hold the jog button to turn the power back on and move the table when the part stops?
    Do you have the space to actually cut the part? Is the tool path coming off the table and running in to the limits of the table?
    Mar 2016
    40
    Quote Originally Posted by leorme View Post
    Do you have a air/oil spindle? I think you might be confusing spindle oil with way lube...
    Apr 2016
    39
    no,the way lube is one thing and the spindle use a cooler to discipate the heat and a fan too,but the fail is not in the spindle
    the machine stops in any axis (when the fail comes)can be x,y,or z.....the spindle have a pump to refrigerate,but i change too
    Apr 2016
    39
    1)yes,2)yes,3)1997,(mod 906-1),4)can be any,depends in wich the machine are working at the moment.5)yes
    6)no the jog dont work when the machine stop(i have to reset the sw-red to work)and then move the table,but loose mi ceros
    7)yes,and run freely
    Apr 2016
    39
    no dont have,just x,y,z...i know,when the A axis install,i have to put a connector and a board,and a valve too on the rear of the machine
    i was making in other machines,as you see i am almost an expert on machines but i dont know this fail..thanks
    Mar 2008
    683
    This is a tough problem. I have a 1997 as well but never had a problem.
    If it is resetting on any axis I am lost. All I can suggest right now is to gain axis to the ball screws and see if there is a mechanical issue with any of the bearings. I still also have a feeling there may just be some loose wires.
    You have me stumped. I suggest an email to Independent Technology Service They have helped me many times and will have the spare parts you need.
    Buena Suerte.
    Apr 2016
    39
    thankyou for all,when you need some tips,maybe i can helpyou....see you body
    Nov 2013
    12
    Encontraste la falla?
  1. spindle will not stop fadal 4020
    By choppermex in forum Fadal
    Last Post: 06-17-2016, 09:59 AM
  2. Z level finish, wont finish bottom of feature
    By jay_dizzle in forum BobCad-Cam
    Last Post: 10-02-2015, 04:49 PM
  3. Problem with side finish (bottom finish is great)
    By tikka308 in forum Tormach Personal CNC Mill
    Last Post: 11-19-2010, 03:40 PM
  4. Fadal 4020 surface finish problems. Help!
    By duane999 in forum Fadal
    Last Post: 05-12-2010, 02:22 PM
  5. Zinc-Plated Finish vs plain finish for threaded rod?
    By Almaz in forum DIY CNC Router Table Machines
    Last Post: 10-21-2008, 08:39 PM
