603,834 active members*
3,395 visitors online*
Results 1 to 5 of 5
    Sep 2008
    15
    Voltage for end switches, but from where?
    Dear experienced Members!
    If I want to put end switches to my stepper drived axis, and I dont want to use external power supply, where can I get it form a motherboard?
    My conception is a sign without any converts.
    If you know something, please do not keep it quiet!
    Alex
    Feb 2007
    4550
    Smile 5 volts from the USB or from one of the drive connectors.
    Alex,
    You can use 5 volts from the USB or from one of the drive connectors.
    Jeff....
    Sep 2008
    15
    I see.
    Dear Jeff!
    It is so simple!
    No resistors, no interface circuit, just USB 5+ to a wire on the switch button, and the other one to LPT input pin?
    Alex
    Feb 2007
    4550
    Smile
    Alex,
    You may have to use a 2.2K resistor to make sure the pin is pulled down however most people use a breakout board with optical isolation.
    http://tinyurl.com/5e5zdu
    Sep 2008
    15
    Ah!
    Yes! This is what I am looking for!
    Many thanx!
  1. Help..Stuck at relay ext dc voltage missing but dc voltage OK ?
    By Dirky in forum Bridgeport / Hardinge Mills
    Last Post: 05-14-2021, 06:39 PM
  2. Limit switches and homing switches
    By AeroKam in forum Open Source CNC Machine Designs
    Last Post: 01-05-2008, 02:56 PM
  3. The relationship of limit switches to home switches.
    By MikeAber in forum CNC Machine Related Electronics
    Last Post: 11-04-2004, 08:28 PM
  4. Limit switches and home switches
    By viktorcnc in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-03-2004, 12:11 PM
  5. Home switches and limit switches.
    By ynneb in forum CNC Machine Related Electronics
    Last Post: 04-08-2004, 11:32 PM
