603,380 active members*
3,475 visitors online*
Results 1 to 10 of 10
    Feb 2006
    37
    vxb linear rails
    Has anyone used the VXB system? I am looking at getting a 20mm rails with blocks for my small 3'x4' cnc router (y axis). Thanks.
    Jul 2005
    668
    Quote Originally Posted by alexis221 View Post
    3x4 is not small for unsupported 20mm rails. Expect a lot of flex.
    Steve
    DO SOMETHING, EVEN IF IT'S WRONG!
    Feb 2006
    37
    vxb rails
    That is my concern. Anyway to support the length for no flex? Thanks.
    Feb 2005
    39
    Get the pre drilled ones so you can attach some supports. Thats is what I am going to use in my build. I will make some supports out of 3/8 in flat bar. I will mill a 20mm radius to mate with the rail and bolt it to my frame. Hope to have pics soon.
    Nov 2006
    i am looking at doing basically the same thing.
    20mm rails with the open linear bearing
    the rail will be supported at each end with aluminum support blocks
    and strip of either aluminum or mdf running under the rail to keep it from deflecting.
    i will probably use mdf for budget reasons.
    it should do the job good enough since they just have to sit there and support the rail.
    i wouldnt think the rail will be pushing down hard enough to deform mdf.
    Jul 2005
    668
    There are significant side to side forces also.
    Steve
    Feb 2006
    37
    What about drilling an tapping for some support rods that could be welded to my metal sub frame about every 6inches. As I said earlier I would think its pretty tuff drilling into hardend steel never mind tapping oh my....This would eliminate down flex and side to side motion. Has anyone attempted drilling if so how did it go and what kind of bit was used....Thanks.
    Nov 2006
    51
    well i decided to go ahead and throw down another $10 per rod and go with the 60" drilled/tapped rods.
    and i guess i will make some support blocks out of aluminum to bolt to them.
    hopefully with that rod and decent supports there will be little or no flexing.
    Jan 2006
    357
    I managed to drill and tap the ones I bought, they did not offer drilled and tapped when I bought mine. It took two carbide end mills to do it. That stuff is real hard!
    Feb 2006
    37
    I didn't see any info on their site for ordering them pre drilled and tapped....uugghhh...Well, I'll just have to attempt it myself...Thanks...any pics.....Just checked the site and there they are 3 pages from the 20mm section....
  1. DIY Linear Rails
    By JerryFlyGuy in forum Linear and Rotary Motion
    Last Post: 11-30-2009, 12:48 AM
  2. linear rails
    By lgalla in forum Linear and Rotary Motion
    Last Post: 02-08-2008, 11:35 PM
  3. How to cut linear rails
    By IQChallenged in forum Linear and Rotary Motion
    Last Post: 06-07-2006, 12:20 PM
  4. Linear bearing spacing & Sizing linear rails?
    By fyffe555 in forum DIY CNC Router Table Machines
    Last Post: 12-07-2004, 08:09 PM
  5. Linear rails, rod which is better for cnc?
    By snokid in forum DIY CNC Router Table Machines
    Last Post: 12-30-2003, 02:12 AM
