603,794 active members*
4,810 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > WABECO F1200 MILLING MACHINE
Results 1 to 5 of 5
    Jul 2012
    I have plans to buy a wabeco F1200 milling machine. I read a lot of positive reviews of this machine. But when I was studying the drawings (and parts list) in the instruction manual I found that the bearings of the (head)spindle were BALL bearings and not TAPERED ROLLER bearings. I have always thought, that the right bearings for the spindle were tapered roller bearing, because of the radial and axial forces tot the spindle. Even cheaper Chinese mini mills (like optimum BF20) have tapered roller bearings. So I don't understand why such a good brand have chosen these (wrong?)ball bearings. Does anyone have some idea?? I think this is important to know before I will buy this machine!
    Regards,
    Aart
    The Netherlands
    Feb 2006
    7063
    Virtually all "real" milling machines use precision angular contact ball bearings in the spindle. Only cheap Chinese machines use tapered rollers, because they are much cheaper.
    Regards,
    Ray L.
    Apr 2005
    419
    As ray has said, in the spindle ball bearings are superior to tapered roller bearings in almost every way.
    Jan 2005
    1943
    Tapered roller bearing work great on my trailer. As stated, precision angular contact ball bearings are best for a spindle.
    Commonly use in benchtop machines are also deep groove ball bearings. "Deep Groove Spindle Bearings - Deep groove ball bearings have full shoulders on both sides of the raceways of the inner and outer rings. They can accept radial loads, thrust loads in either direction, or a combination of loads.
    The design of deep groove bearings make them suitable for the addition of closures which help exclude contaminants and retain lubrication." These are likely what they used.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
  1. CNC Milling Machine Packages and Bespoke CNC Milling Machines
    By worldofcnc in forum News Announcements
    Last Post: 05-27-2010, 02:20 PM
  2. wabeco.
    By eddythefly in forum European Club House
    Last Post: 05-30-2008, 06:36 PM
  3. Choice stepper motor for Wabeco F1200
    By debutpic in forum Stepper Motors / Drives
    Last Post: 08-27-2006, 10:07 AM
