588,566 active members*
5,426 visitors online*
Results 1 to 4 of 4
    Sep 2015
    18
    Walter Grinder Controller help
    Hi all, I have some questions about a Helitronic R-Model and its controller. I have no idea where to start looking so i decided to post here. I have a Computer running windows NT with the Walter Windows Mode 500 NT software controlling the machine. The computer took a crap today but luckily i had an old power supply and was able to fix it. But since this computer is old and could fail i was wondering what my options are to upgrade the computer system. I contacted Walter Grinder Inc(they sold/built the machine) to see what i can do, they quoted me a lot of money to come out and upgrade the machine to run windows XPandTool Studio. I was wondering if i can do that myself without upgrading the machine's controller. Best case scenario for me would be to get a windows 7computer, install the necessary software to control the machine, and keep it as simple as possible for the operator.
    Some details of the machine are: Built July 2001, 450 volts, 3 phase, 60Hz, Largest motor amps is 31, KVA 25. I dont know the model of the controller itself, i couldnt find any markings to identify it.
    Is installing a Windows 7or XP with new software a possibility with the old controller. Someone told my colleague that the controller is too old for the new software, but that was a long time ago and he has no details beyond that.
    Any help, ideas, suggestions, would be greatly appreciated
    Thanks for the time
    Jun 2004
    511
    Re: Walter Grinder Controller help
    Why not simply clone the hard drive, and get new hardware, and build a computer to run the same way that you are running now?
    Sep 2015
    18
    Quote Originally Posted by ifixcnc View Post
    That is an option but i would be worried about the Windows NT operating system not supporting new hardware and their drivers. I would need a couple serial ports and i am not sure if they would communicate with the cards being the OS is so old.
    Jun 2004
    511
    I would built an old style computer with New Old Stock parts.
  1. Help with Walter Grinder HMC 500.
    By shemon in forum Toolgrinding / Toolgrinding Machines
    Last Post: 11-10-2014, 09:21 PM
  2. Walter Grinder
    By Burnout2676 in forum Toolgrinding / Toolgrinding Machines
    Last Post: 08-13-2013, 01:07 PM
  3. T SLOT MILLING CUTTER PACKAGE 5 (ON WALTER CNC CUTTER GRINDER)
    By dharschman in forum Toolgrinding / Toolgrinding Machines
    Last Post: 09-13-2010, 06:25 PM
  4. Affordable Centerless Grinder CNC Controller
    By Chaka in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-18-2009, 08:31 PM
  5. Walter CNC Tool and Cutter Grinder
    By valexim in forum Employment Opportunity
    Last Post: 01-21-2007, 02:31 AM
