The light has sort of gone off after seeing the following.
+12V is not necessary, +5V and ground needed
PWM = TTL (0V or +5V), There are no negative pulse. The duty cycle give the speed from 400 (0% duty cycle)to 6000 rpm (100% duty cycle)
F/R and S/P active on level not at level change (levels must be maintained)=>
LOW for F/R = reverse HIGH = Forward
LOW for S/P = stop HIGH = On
So before I hook this up I'd like someone to double check my thinking as I am a "Clark Griswald" level electrician. Following the above I need to take a small 5 volt power supply and connect it to the GND and 5v pins. The PWM would be pin 14 out of the PC. I could then use output 1 on the Gecko to trigger Start/Stop and use output 2 on the Gecko to trigger FWD/REV. Correct. I could also tap a solid state relay into output 1 to trigger the coolant pump. Correct?
