603,311 active members*
1,994 visitors online*
IndustryArena Forum > Other Machines > Other Machine Topics > Want to get an old Model Master CNC mill up and running again
    Feb 2024
    Hello. I've got a 24 year old Model Master 1500 cnc mill which has sat idle for the last 10 or so years due to the hardware and software being out of date. The Model Master company closed years ago, ArtCam, the software I used to produce the art is no longer supported and the mill's hardware is out-of-date, using old serial connections that are not supported by modern computers. My question...can I upgrade the hardware to work with newer software? The mill itself is in good condition. Any help will be great. I don't know where to begin looking other than to ask here.
    Thanks,
    Rod
    Jun 2005
    1785
    Re: Want to get an old Model Master CNC mill up and running again
    You should post some photos of your machine, but the simple answer is YES. Most of these older machines need to have the electronics swapped out for something current. Depending on the Servo Motors and Servo Drivers or the Stepper Motors and Stepper drives some of that hardware can be used again with a new CNC controller. There are many choices, so with a few photos and more details on your machine several people can make suggestions. Also, what is your background, are you familiar with working on electronics and wiring up motors, switches, etc. As far as the older Artcam software is concerned it will still create artwork and generate gcode. The newer replacement to Artcam is Vectric Aspire which is very similar to Artcam, think some of the people from Artcam created it.
    Bottom line is you can use your existing software provided you don't use a controller that is unsupported.
    Mar 2024
    Hi all. I am newbie. Glad to be here. Have a nice day everyone!)
    @rgentry23
    Hello, have you made any progress on your mill startup? As of today I find myself in the same situation. an old machine and software and looking to upgrade the electronics and software. The hardware is reusable.
    My machine is still in use but has intermittent failures. The goal is to replace the wiring and control box and have it continue to work with ArtCam software. I can engineer a suitable solution but in you have any experience to share I would greatly appreciate it.
    I am looking at the OpenSource BuildBotics controller as a solution. There are other options but this is a plug and play fit.
    thanks
