Hi, just got my Water cooled spindle today.
Could someone simplify the process in a step by step way.
The motor is a 2.2Kw with matched inverter
The motor has only 3 pins, 1, 2 and 3 ,no ground connection
Does the inverter needs a 12v supply
Do I need to connect the 220v line after everything have been hooked up.
Thanks as always for any help, Jeff
