Hello Everyone, I've been searching for a solution to fix my 1984 VMC40's lack of way lubrication and have come up dry so now last resort I'm asking here In hopes someone's knowledge will help me.
The problem is that I do not get even way lubrication to all of the oil ports, I've checked the pump's filter and have been manually pumping, I see oil moving through the system and it only comes out in a few places ( it pour's out only on one spot on the x-axis, there is a little bit of oil on the y and barely none on the z). When jogging the table to one side I can see the grooves cut into the tables ways, out of the four I could see two were plugged up with a black powdery dust/grime, I removed what I could from the oil grooves but still didn't solve my issues. I know I'm getting oil to the manifolds and I believe the issues is coming from plugged oil passages in the ways.
The only fix I have found is to it take the table, saddle, and column off and clean the oil channels, blow out the lines and reassemble. The problem with that is it looks like a pain in the @$$, my shop is very small and I don't have room to navigate a overhead crane (or an engine hoist) into position to lift the castings. Plus that takes a while and as in most situations I need this machine running sooner than later.
I had an idea of flushing each individual line with kerosene using compressed air, draining and repeating to flush out the build up, but this only would work with the x-axis because gravity is in my favor. plus I don't know if the junk would work its way into the ways more and cause more wear.
Does anyone have experience or suggestions with situations like this?
Is there any way of properly flushing the way oil channels without removing the column, saddle and table?
I'm trying to start a company with this machine, I need this making chips very soon. Any help will be very appreciated!!!
Thanks for your time.
-Jesse
