588,068 active members*
4,883 visitors online*
IndustryArena Forum > CAM Software > Mastercam > wcs view manager
    Nov 2005
    244
    wcs view manager
    Is the a good link to video tutorials on creating a new Wcs and indentifying them?
    Ex. You create 3 or 4 and want to see which one is active as you are creating toolpaths and when you go back to check your work.
    It appears I create them correctly but when I hit F9 key I get just the brown lines and not the blue lines. It would be nice to show on the screen wcs and a name you gave it.
    Mar 2005
    461
    Once you're in the "View Manager", highlight the desired WCS, then press the "=" button which moves all planes to the selected WCS, then green-check out and you should then see 2 sets of lines when you press F9. The exception would be if the selected WCS is at the same location as the system WCS you will probably only see the brown...
    The other thing you can do is enter settings, configuration and select SCREEN (I think) and there are some options about displaying planes on screen. This should help you visualize which WCS is currently active...
    If this doesn't answer all your questions, post back in here and maybe I can fly over to work (5 minutes) and get the hasp and possibly make you a movie clip or at least be able to answer more accurately.
    Nov 2005
    244
    wcs
    Thanks Matt
    I will try that out tommorrow.
  1. file manager for CNC - web based
    By liquidrc in forum OpenSource Software
    Last Post: 10-25-2011, 08:59 PM
  2. PWM manager programme error
    By k-linkz in forum Hobbycnc (Products)
    Last Post: 07-07-2005, 10:56 PM
  3. WorkShop Manager from System 3R
    By Tulak in forum Uncategorised MetalWorking Machines
    Last Post: 10-07-2004, 04:18 PM
  4. The NC manager !!
    By HuFlungDung in forum OneCNC
    Last Post: 05-24-2003, 10:55 PM
  5. OneCNCxp's NC manager is da sh...!
    Last Post: 04-09-2003, 01:43 AM
