I bought a nice working BP-12 and this is my fist CNC and not sure how to work it
I know how to reference the machine and move it around in MDI mode. But need some help in running a saved file. The machine has 2,200 saves programs on it. so plenty to test.
Is there some thing that needs to be set after turning on the machine with tooling?
When I go in to WoodWop I can load a file and it is visible on the screen. What do I do next?
This is what I tried, push the vacuum pedal the vacuum tuns on the back pins go down, step back and push the green start button and nothing happens. And some times the back pins go down and a second latter the vacuum goes off and pin go up.
But it's fun to see the machine go 60 meters/min and stop to with it .02mm
