587,593 active members*
3,961 visitors online*
Results 1 to 4 of 4
    May 2017
    49
    Weird problem at MACH 3 on my DIY
    Hello, i think the mach 3 users can help me here. I was testing for the first time my DIY alum machining center and got this weird G-CODE toolpath at MACH.
    As you can see at the right corner, there is a strange loop on the part, but the toolpath was supposed to look like this:
    I use the MasterCAM 2017 with a post processor called Boss_Mach3, that is created by the users for the X versions of MCAM.
    To use at MCAM 2017 we need to update for 2017 using the UpdateUtility.dll provided my Mastercam itself. I don't believe this affects anything.
    The code is being generated without errors.
    The strange loop thing on the part( I hope you guys can see it on the image) happens on this line of code:
    It's a G2, when my machine goes into that line, if you take a close look at MACH 3 SCREEN IMAGE, you will be able
    that the line itself happens like 10 or 20 times.
    N5090
    N5090
    N5090... so many times. And my tool keeps spinning.
    Does anyone knows what is happening? My coordinates are absolute, my IJ is working on relative coordinates.
    Aug 2016
    119
    Re: Weird problem at MACH 3 on my DIY
    I've seen similar issues when there's an extremely short arc segment in the original geometry. Smoothing arcs prior to post processing usually fixes it
    Mar 2003
    35538
    In Mach3, go into General Config and change the IJ mode to Incremental, and see if it fixes it.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    May 2017
    49
    Quote Originally Posted by Blackened View Post
    This isn't the case, i really believe that my problem is that i am running a demo, it only works until line 500 so when it hits line 500,
    it repeats the 500 line.
    I took a look and the G2 problematic line happens on the 500 line.
    So it's probably the cause of it, i ran several other programs today without reaching the 500 line and it wen't fine.
    My IJ are already incremental.
  1. Mach 3 making weird cuts, not following Gcode
    By justCNCit in forum Mach Software (ArtSoft software)
    Last Post: 04-06-2016, 01:24 PM
  2. Weird Mach issue
    By keithmcelhinney in forum Novakon
    Last Post: 02-05-2016, 12:40 PM
  3. weird sync issue with mach 3 and tb 6560 driver
    By miniarcade in forum Mach Software (ArtSoft software)
    Last Post: 02-12-2015, 03:20 AM
  4. i've got a weird problem
    By fast89 in forum CNC Machine Related Electronics
    Last Post: 12-19-2007, 09:31 AM
  5. Windows XP Pro and Mach 3 weird stuff
    By rwaudio in forum Machines running Mach Software
    Last Post: 10-04-2007, 03:05 PM
