Machine wouldn't power up. Turned out I had a bad power supply. Got it repaired and re-installed and was able to get the controller and spindle to come up.
But now I have another issue that I'm having problems solving.
The controller goes through it start up and says Diagnostics Passed and then says Power Fail. See attached photo.
The manual says replace battery, which I did and still get the same error.
Weird thing is, if remove the battery and put it back in with the controller on, it comes on up.
Any ideas? I don't want to have to take the battery out every time I start up the machine
