587,997 active members*
2,048 visitors online*
IndustryArena Forum > MetalWorking > Welding Brazing Soldering Sealing > welding 6061 alum before chrome plating
    May 2008
    4
    Angry welding 6061 alum before chrome plating
    I have a large piece of 6061 aluminum that has a 1 inch hole in it (oops) and the material will finish at about .430 thick. My thought is to bore the hole and make a over size plug, (press fit) and have it welded on the inside of the cover. After I am finished machining it, the outside of this motorcycle cover will get chrome plated. The question is, should I also weld the side that will get chrome plating also? Will the welding affect chrome plating? Thanks:
    Oct 2005
    118
    If you can make a interference fit to start. weld the inside and then blend the outside so it is perfectly flush there should not be a problem with a chrome part. If you had to anodize the part over a weld it would be very noticeable. Prolly the best bet would be a triple plate, copper, nickel, chrome.
  1. Triple Chrome Plating Kit
    By SScnc in forum Material Machining Solutions
    Last Post: 06-03-2009, 08:38 PM
  2. Replies: 7
    Last Post: 05-02-2009, 12:07 AM
  3. Chrome Plating - Aluminum
    By cdlenterprises in forum Employment Opportunity
    Last Post: 10-12-2007, 12:12 PM
  4. plating 6061
    By dafowfidy in forum MetalWork Discussion
    Last Post: 01-29-2007, 03:39 PM
