587,633 active members*
3,461 visitors online*
    Dec 2010
    Welding aluminum
    My question is why do I have a hard time welding .125 to .250 aluminum
    I have my tungstun 3/32 cup is # 7 amp at 160 start at half knob set to auto Im having a hard time starting a pool when it does start my welding is not shiny its dull when finish
    Jan 2010
    485
    Are you using AC to weld with? Are you cleaning the joint free of oil and other contamination first? What gas are you using? What flow rate on the gas? More is not always better.
    A book on welding will give you pointers, or go to your welding store and ask them to look at your weld and ask for suggestions
    Dec 2010
    Yes AC with argon gas all cleaned before weld gas flow is at 18 lb knob at 7:00 o'clock
  1. Mig Welding Aluminum
    By gibbsman in forum Welding Brazing Soldering Sealing
    Last Post: 01-14-2011, 05:20 AM
  2. Amperage required for TIG welding aluminum
    By cjjonesarmory in forum MetalWork Discussion
    Last Post: 06-27-2009, 12:36 AM
  3. Tig welding aluminum
    By larry53 in forum Welding Brazing Soldering Sealing
    Last Post: 02-05-2009, 06:15 PM
  4. aluminum cutting/bending/drilling/welding
    By hyperdyne in forum Employment Opportunity
    Last Post: 01-19-2009, 07:24 AM
  5. Cleaning aluminum for welding
    By damae in forum Welding Brazing Soldering Sealing
    Last Post: 01-05-2007, 08:49 PM
