Hi: I have the same welder. First of all, remember that the Tensile strength of the weld is 70,000 psi. So, you do not require as much as you think in order to build a brick craphouse. make sure that you remove the rust and scale from the parts you are going to join. For the plate/tube weld crank the welder up to level 4 and set the feed to 50% (this is the factory set sweet spot), and run a bead on a test coupon. Then, tack as usual, run 2 passes, and you will be fine. You may even get away with a single pass if you weave the bead, concentrating more on the 3/8 plate. Try to weld in the horizontal flat position. Most of the welders are capable of more, but for liability reasons, they are underrrated.
Practice on coupons befor you tackle the real part.
regards
Can't Fix Stupid
