Originally Posted by
C.Michael
I have the same 1250..using Mach 3 and THC 300 from Campbell..I had the same problem with high taper..Your torch is too high creating the taper as it runs..try this..during the middle of the cut, hit the stop button on mach and this should stop movement and cut the torch off..Then measure your torch height off the table with a stack of feeler gauges..is it .063 like it should be? I bet it is closer to.1 of an inch..turn your torch height voltage setting down to lower the torch down maybe 2 volts at a time with each new test run..
With the thc 300 that I have, it only takes just a touch of a rotation of the knob to make the difference in voltage reading..You should be able to make a cut, where the piece fall through to the floor after it is done. just adjustments of 1 or 2 volts..And you will know when you hit it because it will be a beautiful cut..
Then what I do to capture the exact location of the knobs is take a digital photo of the THC panel for future reference..showing the exact position of the knobs..Because different steel thicknesses require different knob settings and the photos will keep the record of it..
