603,799 active members*
3,058 visitors online*
Results 1 to 5 of 5
    Oct 2007
    152
    What am I doing wrong
    Hi, when using one of the Newfangled Solutions Wizards before going to the wizard I zero the X,Y and Z to the fixture that I want to mill, after filling all the needed parameters and pressing the Post Code button and Exit I am back to the Mach3 screen.
    Then when I press he Cycle start button the spindle moves up, but to far up and I have to move the Z back to the fixture again rezero it another time, if for some reason or another I have to move the spindle in another spot I only have to rezero the X and Y the Z is OK.
    Hoping to be clear enough
    Thank you
    Mar 2003
    35494
    It the wizard adding a G43 for tool length compensation?
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Oct 2007
    152
    Hi, thank you for the reply, is there a way to avoid that G43 from happening other than edit the file every time I use a different wizard and where those the wizard get the length of the tool I don’t recall entering any length of any tool
    Mar 2003
    35494
    I don't have a Newfangled License, so can't really help you with that. What does the code look like?
    Gerry
    Oct 2007
    152
    Hi, with the G43 you struck wright on the button, I must have had wrote it in the offset tool and didn't remembered it.
    Thank you
  1. 10 IPM, am I doing something wrong?
    By jupdyke in forum Mechanical Calculations/Engineering Design
    Last Post: 09-16-2009, 04:26 PM
  2. What's wrong here?
    By CharlieM in forum Uncategorised CAM Discussion
    Last Post: 10-31-2008, 08:50 PM
  3. What am I doing WRONG???
    By elalto in forum Mach Software (ArtSoft software)
    Last Post: 07-21-2006, 11:23 AM
  4. anyone know what i am doing wrong
    By pauluk in forum Digitizing and Laser Digitizing
    Last Post: 02-16-2006, 05:48 PM
  5. I & J vs R, what went wrong
    By little bubba in forum Fadal
    Last Post: 05-03-2005, 12:23 AM
