587,216 active members*
2,463 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > What best choice of Hiwin Linear for DIY CNC?
Results 1 to 6 of 6
    Apr 2011
    147
    Hello, Now my CNC was finished and i will back to do my 3D CNC model to complete it to standard size and sale my plans for anyone who need to DIY CNC but don't need to drawing it to save your time and more.
    I'll sale my plans as 3D google sketchup and some description (maybe not much ,i'm not good in English) But you can view , rotate view , zoom , edit or use it to custom you size need , after i finish my plans and sale it i really hope it should be personal use only , not for sharing , not for public. If i need to make it Opensource it should be from me.
    But now i have problem to choice series of linear for what's better choice for CNC size about 1200x1000x300mm
    What is better choice?
    - HGH 15CA
    - HGH 20CA
    - HGH 20HA
    Now i think i will use Hiwin HGH 20CA for X,Y,Z Axis.
    Note :: I will do 3 standard size for my 3D google sketchup plans
    - 1200 x 1000 x 300mm (working area 1000 x 850 x 150mm)
    - 1000 x 800 x 300mm (working area 800 x 650 x 150mm)
    - 800 x 600 x 200mm (working area 600 x 450 x 100mm)
    Any advice ,any comment , any question , any recommend please please.
    What you could get from my plans?
    -This as example of my plans.
    Jan 2012
    394
    i went with the AGW. If they still have the LGW left, go for those, however, they didn't have the options in the size I needed, so I went with the AGW.
    The new HiWin will cost you about double.
    Either way, You want the ones that are preloaded bearrings. Z1 product code on them. Also, in a dusty environment, like a wood router goes through, it may be worth it to get the option scraper/seal kits.
    stay with 20mm blocks and rails all the way around. If you can afford, I'd switch to 25mm rail for the y-axis.
    Oct 2004
    590
    Quote Originally Posted by iD2 View Post
    If you're going to 'design by committee' isn't it in principle 'open source' already?
    Apr 2011
    147
    Quote Originally Posted by Falcon69 View Post
    Thank you.
    Quote Originally Posted by OCNC View Post
    May be you right. i'm try to make this plans good and choose the right linear guide way and it will good for anyone who need to buy this plans and use it as tutorial for build it for they own.
    I need to think about that you said it true. But i try to make this plans for newbies like me and sale it for cheap.
    Jan 2012
    28
    So how much are the plans??
    Apr 2011
    147
    Quote Originally Posted by hollisin View Post
    Now i have 2 choice in my mind
    - 9.99$
    - 14.99$
    But now 70% of my mind will sale it 9.99$
  1. NSK or Hiwin linear bearings?
    By AK_Five-O in forum DIY CNC Router Table Machines
    Last Post: 02-10-2011, 10:07 AM
  2. hiwin linear guides
    By eloid in forum DIY CNC Router Table Machines
    Last Post: 12-05-2007, 03:04 AM
  3. hiwin linear rails
    By eloid in forum CNC Wood Router Project Log
    Last Post: 11-28-2007, 02:55 AM
  4. HIWIN linear guide too tight
    By IQChallenged in forum Linear and Rotary Motion
    Last Post: 12-21-2006, 09:19 PM
  5. hiwin linear rails
    By daedalus in forum Linear and Rotary Motion
    Last Post: 11-18-2006, 02:32 AM
