What CAD command converts a 2D sketch into a 3D solid
thanks you
thanks you
What CAD program are you using?
In AutoCAD, it's Extrude.
Gerry
UCCNC 2017 Screenset
Mach3 2010 Screenset
works, thanks you!!!!
You can use many tools to convert sketch to solid model.
Try the following commands.
Extrude (ext)
Loft
Revolve (rev)
Sweep
:idea:
They say the correct answer.Its "Extrude".
There is also a simulation process which auto company used for Sheet metal forming.
Its not only auto cad but its a Autoform.
