603,946 active members*
3,182 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > What is this called and where can I order it?
    Mar 2005
    215
    I have a Dyna 2400 mill that I am converting to Servo drive. I decided to strip down the machine to give it a good once over even though it looked to be in good shape. The lead screws for each axis is covered by a black rubber accordian boot to protect it from junk getting in there. On my X axis one of these boots is falling appart and I need to replace it. Does anyone know what they call this stuff or where I might be able to order it other than through Dyna?
    Thanks for any help.
    AC
    Dec 2003
    24260
    Albert E.
    Mar 2005
    215
    Thanks That is exactly what I needed.
    AC
  1. What are they called
    By Rhodan in forum Community Club House
    Last Post: 08-23-2006, 06:29 AM
  2. Blind Teeth or so they are called
    By pinguS in forum MetalWork Discussion
    Last Post: 08-02-2006, 08:56 PM
  3. What is the white plastic called?
    By WarrenW in forum Mechanical Calculations/Engineering Design
    Last Post: 12-24-2005, 03:39 PM
  4. Order to purchase
    By CanopyFx in forum DIY CNC Router Table Machines
    Last Post: 05-02-2005, 09:24 PM
  5. Congratulations are in order
    By Turbine in forum Community Club House
    Last Post: 01-05-2004, 07:48 PM
