588,445 active members*
5,601 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > What cutting fluid do you use?
Results 1 to 8 of 8
    Jun 2010
    1414
    I use Mobilcut 102. I was curious what everyone else uses. I mostly cut copper and aluminum. Koolmist worked for the aluminum, but it didn't work well for copper.
    My problem is that the grainger by me closed down. Now I am looking to purchase online and figured I would get more input from you guys.
    Feb 2004
    1311
    I use Koolmist for both aluminum and brass as a mist. What was the problem with copper?
    cheers,
    Michael
    Reelsmith, Angling Historian, and Author of "The Reelsmith's Primer"
    www.EclecticAngler.com | www.ReelLinesPress.com
    Feb 2009
    6028
    We use blaser on everything. I will say the dedicated copper guys all use flood oil, not coolant.
    Jun 2010
    1414
    Copper seems to need a thicker oil, the koolmist as a flood coolant didn't seem to work. Worked great with aluminum, but just not copper. I still don't know jack, but that was just my experience.
    Feb 2008
    194
    I've been using Trim E206 as flood coolant. Seems to work well, I haven't had growth problems, and it works over a wide concentration range so I don't worry too much about keeping that in balance.
    I tried Koolmist for flood, but it doesn't offer very much lubrication even when mixed in stronger batches. It also seemed to lead to rust, where the Trim E206 that I use dries into a oily/greasy residue that protects steel. Koolmist (as the name implies) seemed to work pretty well for mist cooling.
    Jun 2010
    1414
    Quote Originally Posted by awetmore View Post
    What is the mixing ratio of the Trim E206 with water?
    Feb 2008
    194
    Quote Originally Posted by nateman_doo View Post
    http://www.masterchemical.com/db-docs/pdf_di/E206.pdf
    3-10% is the recommended range.
    I mostly work in aluminum and probably run about 8-10%.
    Jun 2010
    1414
  1. Cheap cutting fluid
    By ftkalcevic in forum Australia, New Zealand Club House
    Last Post: 05-06-2016, 08:01 AM
  2. Cutting fluid for aluminum?
    By Ben in forum Uncategorised MetalWorking Machines
    Last Post: 11-17-2011, 04:03 PM
  3. What cutting fluid are you guys using?
    By douglasco in forum CNC Swiss Screw Machines
    Last Post: 07-13-2009, 01:02 PM
  4. Cutting fluid
    By sleeper142 in forum Haas Mills
    Last Post: 07-29-2007, 02:05 PM
