![Quote](images/misc/quote_icon.png)
Originally Posted by
cadman
The 7000 series is a higher strength alloy than the 6000 series and contains larger amounts of zinc & magnesium. In general, aluminum such as 7075-t6 does not require heat treating after welding.
The 7000 series is a little tougher to machine compared to 6000 and tends to be more free machining. It is not as ductile. When machining any aluminum you do not want the chips to stick to the endmill. If you have a problem with that it could be feerates too slow, rpm too fast, wrong number of flutes (too many) when slotting/pocketing (chips not evacuating), depth of cut too deep, or lack of lubrication/coolant.
7000 series corrodes more easily than 6000 and will discolor quickly when using synthetic coolants.
You CAN NOT WELD 7075 aluminum.
You can buy GOOD PARTS or you can buy CHEAP PARTS, but you can't buy GOOD CHEAP PARTS.
