588,182 active members*
4,427 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Controller & Computer Solutions > What is the difference between an industrial computer and a normal computer?
Results 1 to 10 of 10
    Feb 2004
    427
    So I want to make an industrial computer one day. The biggest issue that I will need to cover is that it will need to be dust proof.
    What makes an industrial computer an industrial computer?
    Maybe the enclosure that they are in is made of thicker grade sheet steel?
    Maybe they are air tight or dust tight?
    So if I need to make a dust proof computer case/ controller enclosure. How will I keep it cool?
    I can't just make it an airtight box, casue the heat from all the drivers and power supplies will cook everything. So I would need to add probably two holes to the case. One for air flow in and one for aitflow out.
    But
    Will just a simple foam type sponge be good enough as an air cleaner? These will be for use in welding and fabrication shops where lots and lots of grinding and plasma dust will be.
    My last plasma machine, there was dust everywhere. All over the monitor, all into the computer vents.....everywhere.
    The computer didn't short out or anything, but I still need to make an enclosure as robust and clean as possible for all the electronics.
    Any ideas?
    Cheers,
    Peter
    My little site on MIG welding http://www.learn-how-to-weld.com/mig-welding/
    Dec 2003
    24220
    Quote Originally Posted by Apples View Post
    About $5,000.00
    Of all the systems I have installed, I have never sprung for an industrial PC, I have never found them exceptionally different except being a bit more rugged.
    I have found it much more practical to pick up a suitable electrical enclosure such as supplied by Hoffman or Hammond and build an off the shelf PC into it, I generally fit a fan with a filter with air directed in, at the opposite side a exit filter, this keeps the enclosure positive pressure.
    The front or door can be fitted with switches or push buttons and panel mount LCD if desired.
    Al.
    Albert E.
    Feb 2004
    427
    Well, I think I can do more for $5000 rather than spending it on a computer.
    Yeah this is what I was thinking.
    What about mounting a monitor, either normal or touch screen. My flat screen lcd infront of me now has the moulded plastic "case" or frame around it.
    I would want to some how;
    a) be able to bolt it firmly to the front door off the enclosure. I might need to ge a specific model lcd for that. I have seen some on the net before that have like angle brackets on them or similar so that you can screw them on.
    b)It must also be dust proof. How is this acheived? Do they come with rubber seals or something?
    Peter
    Aug 2005
    578
    I have seen all kinds of mods for the lcd mounts. if using a standard LCD just make brackets that will hold it tightly in place and line the edge with any type of closed cell foam gasket material found at the hardware store. All other surface mount LCD usually come with a mounting kit...... One word of caution, do not run screws into the LCD case unless you disassemble it first to see where they will come into contact......
    Feb 2004
    427
    A bit of foam, yep that was what I was hoping I could use.
    Ahh, what I need to look for is a "surface" mount LCD. And good tip about the screws, lol.
    Thanks,
    Peter
    Aug 2005
    578
    Peter there was no pun intended. If the hole is cut and finished then lined with this gasket it will look very professional and will work without fail. But to each his own.
    Bob
    Sep 2008
    27
    Yet about the computer and ventilation... you can use a mother board that don't need ventilation and so you can close everithing!!
    for example:
    http://www.avalue.com.tw/
    they also seel only the boards and you can make your own box!!
    this computers are not so fast like a desktop but normaly if you want use for an specific aplication must be good.
    Bruno
    Dec 2003
    24220
    What I have done is taken a P.O.S. (Point of Sale) terminal with touch screen and removed the LCD and duplicated the mounting on a square piece of 1/8th aluminum with a suitable window cutout, to make a panel mount.
    The normal method is to use a double sided tape on either the touch screen edge to seal or use a product like Acrylite FF P-99 acrylic sheet to offer a non-glare front and protection to the LCD if a TS is not used.
    Al.
    Albert E.
    Nov 2005
    1468
    You could liquid cool it? Then seal everything airtight.
    Ask at any PC component store- it's quite comon for folk who overclock their machines.
    I love deadlines- I like the whooshing sound they make as they fly by.
    Apr 2005
    438
    Like ImanCarrot says, water-cool it.
    Get a motherboard with build in video and the water cool the cpu, chip set and the memory sticks.
    Zalman has some water-cooling items you might be interested in.
    www.zalman.com
  1. Cnc Computer
    By fjr122 in forum Computers / Desktops / Networking
    Last Post: 04-18-2008, 11:48 PM
  2. Computer Help
    By jamesr in forum Surfcam
    Last Post: 08-25-2006, 02:36 PM
  3. What a difference a computer makes
    By jwatkins in forum DIY CNC Router Table Machines
    Last Post: 07-08-2004, 02:23 PM
  4. fast computer as server, slow computer as terminal
    By replicapro in forum Computers / Desktops / Networking
    Last Post: 07-01-2004, 08:05 PM
  5. Computer For EMC
    By foamcutter in forum LinuxCNC (formerly EMC2)
    Last Post: 06-10-2004, 10:18 AM
