I want to know what is the different between drill bit and router bit, if all I want to do is use the bit to cut plastic 1/8" thick with nice and clean cut.
I did try using 1/8" diameter down cut router bit, the result is bad, just because all the material stay inside and melt on the cut edge, then I use a good upcut wood bit, it is very good and the waste just fly everywhere.
Do the normal drill bit and cut thru the material too, is there any harm to the motor at all, if this is ok, I am thinking to buy the drill doctor too, this is a easy way to shape the drill bit, but so far I do not see any router bit sharpener.
the router is porter 7518, and I use 16000 rpm.feed rate is about 8ft/min.
Any comment, thanks.
