603,335 active members*
3,253 visitors online*
Results 1 to 5 of 5
    What does a Regen unit do?
    Can someone give me a clue on what a regen unit does? I have one in my Tree 325 and I have no idea what it does.
    Jul 2005
    12177
    Do you mean the regen resistors for braking the spindle?
    The unit I have is about 12x4x4 This is part of the Fanuc spindle driver electronics. I read that it is used for braking but I don't know if all motors can use it or if its only a requirement for certain motors or if its used in combination with a motor and the drive.
    I am seeking to replace my Fanuc drive and expect I'll need this but for some reason finding clear information about motor systems has been difficult.
    Dec 2003
    24260
    It serves two purposes, assists in braking the motor for faster stopping and prevents bus over voltage by switching the regenerated voltage into a resistor bank when overvoltage occurs.
    Depending on what drive you are looking to integrate, most VFD's accept external braking as an option.
    Al.
    Albert E.
    One of the things I am trying to do is determine a spindle drive that would be appropriate as a replacement. I don't want to "buy and try", I would like to have a high level of confidence that what I get will work before I get it.
    What I know
    Fanuc - model # A06B-1002-B600 #2000
    200V AC
    4 pole
    3 HP 5 HP Peak
    11 Amps 15 Amps peak
    1800-8000 RPM
    There is an encoder on the motor
    The original control Fanuc a06b-6052-h002
  1. Haas spindel Deriver, Regen problem
    By tayfunk in forum Haas Mills
    Last Post: 04-30-2025, 10:56 PM
  2. 2 month old Haas VF2D, Regen Overheat?
    By locash in forum Haas Mills
    Last Post: 06-04-2014, 01:55 AM
  3. Regen overheat
    By engine tech art in forum Haas Lathes
    Last Post: 02-06-2009, 04:31 AM
  4. Edgecam Bottleneck - ReGen TOO SLOW
    By 1ctoolfool in forum EdgeCam
    Last Post: 05-31-2007, 05:58 AM
  5. regen toolpath kcam
    By oliver in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-16-2006, 01:19 PM
