587,414 active members*
3,018 visitors online*
Page 1 of 3 123
Results 1 to 20 of 41
    Apr 2011
    121
    What electronics?
    OK, next question? We need stepper motors and driver boards.
    I believe Bob used a xylotex stetem. They sell the board, 24V power supply and 3 269 in-oz steppers for $380. This is a bipolar driver board, and I understand that bipolar is prefered to unipolar (but I can be corrected). 1/1, 1/2, 1/4, 1/8 microstepping. 2.5 amps at 35 volts. (why not 36 volts like the power supplies you can get?)
    Then, of course, is the popular Gecko 4 axis controller which goes for about $250 without the steppers. vast microstepping options. 3.5 amps to 50 volts.
    There is also the HobbyCNC board which you have to solder yourself. Cheap at $67, $260 with 200 in-oz steppers. Unipolar only. 1/1, 1/2, 1/4, 1/8, and 1/16 Microstepping. 3.0 amp 36 Volts Maximum.
    Lastly and cheapest are the various Chinese Toshiba chip items that are quite attractively priced, even with overseas shipping. Some as cheap as $200 or so. Similar microstepping and maximum current as the above units.
    So, which way to go? I might be cheap, but I hate paying twice and don't like getting shafted by overseas people who just won't deal with you if there is a problem.
    Sep 2010
    Michael,
    I went with the "3 axis package" deal from cncrouterparts.com which includes :
    - 48V 7.3A switching power supply
    - Gecko G540 4 axis stepper motor driver
    - 3 High-torque Nema 23 380 oz-in stepper motors. These motors already have the current set resistors installed in a pro-grade metal shell. No soldering or crimping required. These are optimized for the G540. These motors use all of the 3.5A the G540 has to offer.
    - 3 High-performance flexible motor cables: (1) 6'and (2) 12' cables
    I also bought the parallel cable to connect the driver to the computer
    My reason for doing so was my desire to get an all in one system without the need to solder a board or construct cables to connect motors to driver. Admittedly not the most economical solution but I was OK with the added costs to the overall project.
    Keep these posts coming as we all benefit from the interaction.
    Dave
    May 2010
    118
    I also went with the CNCRouterParts 3-stepper Gacko-based kit. A bit more expensive, but seemed worth it for reasons similar to those Dave provided.
    I did forget the parallel cable. I hope I can find one in my box-o-cables!
    Randy
    Sep 2010
    Randy,
    Funny you mentioned forgetting the parallel cable as I did the same thing and had to place a second order for it. From research I have done you need to be careful with the cable - "ordinary" parallel cables used for printer connections won't always work. Something to do with not all pins are wired from one end to the other I think.
    Dave
    May 2010
    118
    Dave,
    Good point. You are right, most printer cables used just a few of the available pins. I guess I will have to place another order too!
    Randy
    Apr 2011
    121
    Electronics
    Lets beat on this some more...
    Either confirm my position or talk me into spending more money.
    Hands down, the cost winner for suitable electronics is EBay a matched system from China. Longsmotor (of which there seems to be a couple on e-bay) sells a 270 or so in-oz 3 axis system with 4 motors, combo BOB/Driver board, and power supply for $210 deliverd to the states.
    Thats cheaper than just a Gecko G540 by itself.
    A G540 with motors and PS as a package is north of $500 which is the next best package deal. You can get it with wiring for about $75 more.
    I looked at ala-carte pricing of similar components but couldn't match the price of the Chinese package.
    Ther is some risk that the TB6560 based driver board is a piece of crap, but if thats true, I'm only out the board, not the drives. The drives are not described well in the e-bay postings, but I'd guess they are bipolar 4 or 6 wire drives that can be configured either bipolar or unipolar and the TB6560 board supports both so you can get some variation of speed or torque.
    Help me spend some money guys and gals!
    Jan 2010
    2141
    I bought a similar setup to the one that you are considering. I've been busy with other projects, and so I have not yet completely set it up, so I can't give you a final verdict.
    I got three 290 oz.-in. 6-wire motors from Longs Motor, part number 23HS8610.
    The motors are rated at 1.0 amp per phase. One thing that I did not realize until after I bought them was that the inductance of each winding is rated at 18 mH, which is very high. If you follow the formula for determining the voltage to use based on the winding inductance, you end up with a much higher desired voltage than what can be handled by the TB6560 board. I expect that they will work OK, but the maximum speed may be a concern.
    I have a 3-axis TB6560 board and a 24-volt switching power supply, which I have mounted in a suitable enclosure. I have researched a lot of info about peoples' successes and failures with that board, and I am prepared to deal with any possible problems that I may encounter, because at the moment I need to keep to a budget.
    One note to keep in mind - the TB6560 board is designed to drive 4-wire bipolar motors (it can drive typical 6-wire motors wired as 4-wire motors, which is what I plan to try). The TB6560 board will not drive 6-wire motors in unipolar mode.
    Bearing in mind the fact that I have not yet hooked things up, my recommendation would be that if you want to try the TB6560 board, make sure that the motors that you get have a suitably low winding inductance - that way, if you later decide to go with a different driver board such as the G540, your motors will be well matched to its capabilities. For comparison purposes, the Keling motors with a similar torque rating have a winding inductance of about 2.2 mH, and they also have a higher current rating than the motors that I bought (approx. 2 amps, or 4 amps, depending on how you wire them). My guess is that driving more current through the windings should produce more dynamic torque, even if the rated holding torque appears to be the same as the lower-current motors.
    After I bought my motors, I decided that I would prefer dual-shaft motors to the single-shaft motors that I got (because I want to do some experiments with placing encoders on the motor shafts, and I may want to also place handwheels on the shafts in order to retain some manual operation capabilities, but most people seem to go with single-shaft motors). Keling sells both single- and dual-shaft motors. I have several CNC projects that I am working on, and I plan to get some motors from Keling for those other projects.
    Also make sure that the TB6560 board that you get has a current rating to match the motors that you get. The board that I got was rated for driving 1.0 amp motors, which is the proper rating for my motors, but they also have a version of the board that is rated for 3.0 amps. That rating is set by the value of a resistor on the board (one resistor per axis, that is) in conjunction with a DIP switch setting, and so if necessary you could always modify that after the fact.
    Hope that helps...
    May 2011
    21
    Apr 2011
    121
    Quote Originally Posted by ldanut View Post
    Search this message board for "easy-cnc".
    I like the concept of socketed components, but apparently tech support and board reliability are poor.
    May 2011
    24
    I'm considering a kit from Keling - 3 x 425 oz-in steppers, 3 bipolar drivers in a nice metal box, a breakout board, and a 36V-9.7A switcher. At $399 it is a little more money than the Xylotex, but the modular approach means less to replace if I fry something. I believe all the components are from China, but I feel more comfortable spending a little extra to buy it domestically. A very similar setup with mostly the same components is available from buildyourcnc, but maybe Keling is a more established supplier?
    Apr 2011
    Quote Originally Posted by kemper45 View Post
    Randy,
    Dave
    Yep, cheap printer cables only have the required pins connected, better to get the correct cable and even better to just get it from a CNC supplier so you are sure all pins are intact.
    billj
    Apr 2011
    I went with the ebay chinese model all-in-one kit. Came with a variable 24v-9A (roughly, might have been 8.5A) 3x 287oz.in. 3.0A steppers, TB6560 3-axis 3.5A up to 16 mic steps driver board, parallel cable, and a CD with Mach3 and a bunch of manuals. $210 total and 6 days to arrive.
    I have plenty pics in these forums to see their performance.
    Billj
    Apr 2011
    Quote Originally Posted by bjesson View Post
    Billj
    correction...steppers are 1.0A
    May 2011
    21
    As I was searching for driver solutions I found this miniature drivers that mounts directy on the motor. They are made by UIRobot and can be purchased from here :
    UIM 24002 stepper motor driver
    They seem expensive at $60 each and I was wondering about their real benefit of being small since most CNC's out there are big enought to hide regular drivers.
    Apr 2011
    Wow, those are nice little drivers! They are expensive because of the micro-electronics...smaller is always more expensive in electronics, and they use an aluminum casing which will also act as a heatsink for the stepper. All-in-all very good for tight spaces but not necessary for this version of CNC router. This isn't a "size matters" design. but very cool if you have $180 to invest. I am tempted to try them out. Good find!
    billj
    Apr 2011
    121
    I would add "how do you attach the motor wiring?" Is it internal? If so, are you willing to cut off your wiring to a small nub?
    Looks like a solution looking for a problem. Still got about the same wiring going to the break-out board so what are you saving?
  17. #17
    Apr 2011
    Quote Originally Posted by Michael In Cali View Post
    From the pic on the website it looks like screw terminals to attach the motor wires and screw terminals to attach the extension, you would need at minimum about 3 to 5 inches of motor wire. there is no wiring benefit and the only added advantage would be the smaller footprint and the heatsink. There is no advantage to putting chrome plated rims on a car but it is cool...similar situation here
    billj
  18. #18
    Apr 2011
    they do have one downside and im sure they have another model to cover this issue but this model is a 2.0A max. And one other drawback I just noticed is you would actually be adding more wires into the system at the motor locations because DC is required. So maybe a slight wiring disadvantage as you would have to deal with the extra bulk of cables. The last downside I can think of is the fact your drivers are now in the danger zone for Y and Z axis'. A cool idea but definately not the route I would take for this design of CNC router.
    billj
  19. #19
    May 2011
    21
    Another advantadge of this is that you don't need shielded wires for big currents since it require 5V low current signals. Also another advantage is with high inductance motors that can add noise in cables? Just a tought.
  20. #20
    Apr 2011
    121
    Michael's electronics
    Alright, here is what I decided.
    I'm going to try the SOC Robotics Drivers. I won an e-bay auction for a 4 axis board for about $80.
    SOC Robotics MK4 MM160 Stepper Motor Controller
    I'm going to try these steppers.
    Lin Engineering - Step Motor Specialists
    A bit light weight, but they were cheap. Lin Engineering 5718M-05E-05. They are listed as 8 wire, so I should be able to hook them up bipolar serial or parallel as well as unipolar. For only $41 USD, I'll at least get a working system. If I don't like them, not hard to change.
    Now I need a couple of power supplies. I would like a 32 volt for the steppers and a 9 volt for the driver board. I'm going to check my supply of wall warts for the 9 volt. I can use 24 volts for the steppers and may do that depending on price. I need to stick below 36 volts at any rate.
Page 1 of 3 123
  1. what electronics do i need?
    By yotawheeler in forum DIY CNC Router Table Machines
    Last Post: 12-03-2010, 06:19 AM
  2. Looking to buy some electronics
    By Biff in forum DIY CNC Router Table Machines
    Last Post: 04-30-2010, 12:40 AM
  3. CNC electronics kit , which one ?
    By GLynnC in forum DIY CNC Router Table Machines
    Last Post: 12-02-2009, 02:25 AM
  4. Electronics
    By Bassbuilder in forum CNC Machine Related Electronics
    Last Post: 11-16-2004, 04:34 AM
  5. Electronics help
    By chuckknigh in forum DIY CNC Router Table Machines
    Last Post: 07-18-2003, 03:09 PM
