587,948 active members*
3,746 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > What encoders would you recommend for "Bridgeport Series II Interact 2" CNC conversio
    Oct 2006
    181
    I am doing a conversion of a Bridgeport Series II Interact 2 mill to another control (EMC).
    My question is what are my options to replace existing sinusoidal encoders with incandescent light bulbs.
    I would like to find something that would fit into the existing envelope and would work reliably.
    May 2007
    100
    I am current doing a conversion to an Interact 412, using HEDS Encoders. This is what I did to get them to 'bolt' on.
ID:	108704 Click image for larger version.
ID:	108705 Click image for larger version.
ID:	108707 Click image for larger version.
    Hope this helps
    JH
  1. Weight of "Bridgeport Series II Interact 2" milling machine
    By ichudov in forum Bridgeport / Hardinge Mills
    Last Post: 03-23-2010, 10:21 PM
  2. "Gross Postioning Error A" Doing M03 on Bridgeport Interact Series 1 Mk2
    By MeTri in forum Bridgeport / Hardinge Mills
    Last Post: 12-28-2009, 06:37 AM
  3. How do I "Traverse Axis"? Bridgeport Interact 1 Mk2 TNC 155
    Last Post: 12-28-2009, 12:10 AM
  4. Which "Package Deal" would you recommend ?
    By Dingo745 in forum DIY CNC Router Table Machines
    Last Post: 04-17-2007, 06:31 PM
  5. Bridgeport Series "I" will not home, please help technical school in need!!
    By phantomcow2 in forum Bridgeport / Hardinge Mills
    Last Post: 12-16-2005, 12:11 AM
