603,810 active members*
2,929 visitors online*
IndustryArena Forum > WoodWorking > WoodWorking Topics > What happened to this tool?
    Aug 2011
    Ok, i am a bit of a newbie to the whole CNC thing so please be patiente with me . . .
    I have been using this tool for cutting MDF, 3mm thick. The tool is 3mm too. I used it for about 10-15 hours in different works, not in a signle run. Is it normal for the tool to be "burned" like this? Or am i doing something wrong? The tool still cuts, but the cut is not perfectly clean as it used to be, i have to sand the edges a little bit. Also the tool lost thickness, it's not a perfect 3mm cut anymore. I have more tools to replace this one, but i don't want the same thing to happen again . . . The settings i used for the works i made are, full rotational speed (27.000 rpm) and 150/200 inches per minute.
    Emilio
    Attachment 246482
    Mar 2003
    35494
    Re: What happened to this tool?
    Wrong type of tool, and too much rpm. Try a 2 flute tool, at 15,000 rpm.
    After 10-15 hours, you can expect the tool to be dull, and the diameter smaller due to wear on the cutting edges.
    Also, use a blade or bit cleaner on the tool after each use. The burned on build up adds to the heat buildup and dulling. Clean bits will last longer.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  1. WOW!?!? What just happened!!
    By DC-Modder in forum LinuxCNC (formerly EMC2)
    Last Post: 06-14-2013, 04:55 AM
  2. what happened?!
    By psi.chemie in forum Uncategorised MetalWorking Machines
    Last Post: 03-18-2012, 10:18 PM
  3. When has this ever happened to you?
    By thetrillionaire in forum Haas Mills
    Last Post: 03-02-2008, 05:35 AM
  4. What happened here?
    By turmite in forum BobCad-Cam
    Last Post: 02-06-2004, 03:02 AM
