Its possible it may be a variable reluctance motor, which has no magnets and is very efficent. You would not neccessarily detect the detent like a stepper motor.
Some of the advantages is the motor is brushless and easy to manufacture. The efficiency is high compared to conventional DC and AC motors.
At low speed, almost no losses in the rotor are generated this makes it easy to cool and can thus be small.
It has been around for a very long time as one of the earliest motors, but todays control technology has revived it somewhat.
You may have a problem finding a control for it however, with out knowing the true specs.
Al.
Albert E.
