What methods did you use for sliding motion on your DIY CNC router?
Ball bearing drawer slides.
Unsupported round rails & closed linear bearings or bushings.
Supported round rails & open linear bearings or bushings.
Supported round rails & radial roller skate type bearings.
Hardened & ground liner rails with ball bearing carriages.
V-groove bearings with v-rail tracks.
www.widgitmaster.com
It's not what you take away, it's what you are left with that counts!
INA guides and carriages
Rob C
Mechanical Designer/ Welder Fabricator.
My plasma table uses square tube and 608ZZ bearings. The small mill I'm building is using supported round rails, but I'm chucking the extrusions in the junk bin and machining a solid base for them.
Dave
DIY supported round rail 12mm dia. and gunmetal buschings - machine is Micro-mill with 160mmx80mmx110mm work area.
