588,568 active members*
4,921 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > What motor, screw and gearing should I chose?
Results 1 to 6 of 6
    Oct 2003
    399
    (This thread was meant to go in the FAQ section, but it was moved, maybe it doesn't fit in there?)
    The short answer:
    For a smaller wood and plastic cutting machine (and maybe – maybe! – some light aluminum), several people on CNCzone seems to have had success with 100-200 oz-in (0.7-1.4 Nm) stepper motors direct driving a 5 turns/inch (5 mm lead) ACME (trapezoidal) screw.
    The long answer:
    ... hopefully you can find in the attached file. Please, if you spot any errors or have trouble viewing the file (like missing characters or fonts), write a comment in this thread http://cnczone.com/forums/showthread.php?t=5639, or use the email address in the file to notify me. Other comments are also welcome to my email address.
    Arvid
    Attached Files Attached Files
    Sep 2003
    1113
    WELL DONE! A thorough tutorial. Should be very helpful to anyone starting out. A few pictures as you mentioned earlier would really help. There are some experts out there I'm sure will contribute. Cheers - Jim
    Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
    Oct 2003
    399
    Thank you, Jim!
    I hope it will be useful.
    Arvid
    Mar 2003
    6855
    Resubmit it in the FAQ section again, I will leave it their. Sorry about that.
    Oct 2003
    399
    Ok, will do. Thanks!
    Arvid
    May 2003
    340
    Brilliant
    Graham
  1. What motor, screw and gearing should I choose? v1.2
    By arvidb in forum FAQ of DIY CNC Machine Building
    Last Post: 03-09-2015, 12:47 PM
  2. What motor, screw and gearing should I choose?
    Last Post: 08-17-2010, 05:54 PM
  3. Help with formulas for gearing servos
    By cnctoolman in forum Benchtop Machines
    Last Post: 04-08-2005, 03:13 AM
  4. Reduction Gearing & Backlash
    By UKRobotics in forum DIY CNC Router Table Machines
    Last Post: 04-02-2004, 08:31 PM
