603,405 active members*
3,289 visitors online*
IndustryArena Forum > CAM Software > Dolphin CAD/CAM > What Postprocessor to use with USBCNC
Results 1 to 16 of 16
    Jan 2008
    6
    I´ve just finished retrofitting a Boxford 280 Turnmaster lathe with USBCNC CPU5B professional from Bert Eding (Eding CNC - PC based CNC control). I´ve bought Partmaster Lathe cam from Dolphin.
    Do anyone here know what Postprocessor to use?
    Dec 2003
    259
    Peter,
    Other than suggesting the Mach driver I can't help but I'd be interested to know how it works out as regards threading.
    Mach, using the parallel port is useless. many who say they don't have a problem do have but they don't do long enough threads for it to be apparent.
    John S.
    Jan 2008
    6
    Postprocessor to USBCNC
    Quote Originally Posted by John S. View Post
    Peter,
    John S.
    HI
    I´m beginning to modify the Mach postprocessor, but I´m a newbie to lathe postprocessor, so I´m afraid of making mistakes. I´m done with the groups. Can you se if I´m doing right so far? I´ll try to attach a copy.
    I have tried to make a simple job of turning an arc, but when I load it into USBCNC it tells me: Radius of end of arc differs from radius to start.
    Regarding treadcutting I have not tryed it yet, but I have a sensor on my spindel, and I understand that it syncronise the startpoint of treadmaking (G76 in USBCNC).
    Is it very expensive to get a customised postprocessor?
    Regards Peter
    Attached Files Attached Files
    Feb 2007
    417
    I think the problem with the arcs is a question of the centre coordinates being either incremental or absolute.
    Can you change the setting in USBCNC ? if not the post can changed.
    The standard Fanuc post - T_F0TC, uses incremental - have a look to see the difference between under the macro section, here is the entry
    #I = { (($YCEN-$OLDY)/2):XARC }
    Absolute would be
    #I = { $XCEN:XARC }
    Hope this helps.
    ATB
    Andre
    Sep 2010
    post processor USBCNC by eding cnc
    hi Peter Nielsen,
    I am also using USB CPU V5 by eding cnc for my CNC Plasma/oxy fuel Combo with spendel on it, i also use sheetcam for converting my cad drawing to g-code and i am using the EMC plasma processor.
    Also if you use this on cnc lathe try the EMC, but i am not sure if it work.
    Please send me a feed back what happen because i am also planning to build one of cnc lathe using USB CPU.
    Thanks:cheers:
    Sep 2008
    31
    Hey there,
    any news here? Or still no PP für USBCNC-Turning available?
    Regards,
    Marc
    Plz excuse my english, i'm german
    Jan 2008
    6
    Re: What Postprocessor to use with USBCNC
    Need a postprocessor from EdingCNC USBCNC to Dolphin Partmaster Lathe.
    Do anyone know how to create it or modify and exsisting postprocessor??
    Sep 2008
    31
    Quote Originally Posted by Peter Nielsen View Post
    I'd be very interested in a postprocessor for EdingCNC, too.
    It's somehow disappointing, that even after such a long time and worldwide grown distribution of EdingCNC, there still isn't any matching postprocessor available from Dolphin itself...
    Aug 2014
    889
    It's my understanding that EdingCNC works well with standard Fanuc GCode. So Fanuc 0T or 6T, should be OK provided that Dolphin has a post processor that can spit out the standard Fanuc GCode.
    Sep 2008
    31
    Quote Originally Posted by G59 View Post
    No, it doesn't. I tried every PP of PML, but there is no working one.
    Aug 2014
    889
    EdingCnc interprets standard G-Code ie: RS274/NGC which Fanuc-0T uses.
    DolphinCam surely has a post for this old control?
    I don't use Dolphin or Mach, so can't really help.
    Good luck.
    Jan 2008
    6
    I have also tried almost every postprocessor from Dolphin, but still havent found anyone that works. Now I´m trying to find out how to use the posteditor, but I´m not very good in programming.
    If I find a solution on the problem, i will post it here.
    Jan 2005
    15362
    Peter Nielsen
    Dolphin / Partmaster I'm sure they can help you with your post processor, it needs to output the I's & J's as Incremental, this is industry standard, I'm using Gibbs Cam with Eding control for mill, it is almost perfect with a standard Fanuc type post, most other post processor's also follow the Fanuc style of programing, usually with just a tweak here & there you will have good clean code to run
    Mactec54
    Jan 2005
    15362
    Peter Nielsen
    I ran your program, there is something wrong with your programing, the first ( 2 ) I & JKs work just fine, Line 200 & Line 220 so I think you have a problem with your Drawing or how you are programing your part, your post processor is outputting correctly or line 200 & 220 would not be working as well
    I changed your program some at the top & bottom, removed the I & k lines that were not correct, these need to be correct for the control to run
    Mactec54
    Jan 2005
    15362
    Peter Nielsen
    This may help you with your programing,
    Mactec54
    Jan 2016
    3
    Peter do you still have the Fanuc orginal parameters and diagnostics for the boxford I am in desperate need of some.
    regards Gerry
  1. Eding USBCNC
    By Web Goblin in forum EdingCNC
    Last Post: 05-29-2014, 09:11 PM
  2. g43 usbcnc
    By sapin in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 02-27-2014, 12:53 AM
  3. postprocessor for USBCNC SolidCam 2013
    By solidcamx in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 11-18-2013, 10:14 PM
  4. USBCNC CPU V4
    By Web Goblin in forum Controller Cards
    Last Post: 05-23-2012, 05:23 PM
  5. postprocessor for USBCNC
    By Blerbaby in forum EdgeCam
    Last Post: 10-29-2009, 12:25 PM
