587,997 active members*
2,617 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > Polls > What size CNC Router do you like in your shop
View Poll Results: What is your favorite size for CNC Router table
Voters
252. You may not vote on this poll
  • Less than 2 feet square
    21 8.33%
  • 2'x3'
    47 18.65%
  • 3'x3'
    16 6.35%
  • 4'x4'
    56 22.22%
  • 8'x4'
    54 21.43%
  • larger than 8'x4'
    58 23.02%
Results 1 to 16 of 16
    Aug 2003
    329
    I have been thinking about building myself another CNC Router table for my basement shop. I have a 5'x4' CNC router table available to me but I would like something for the basement.
    What size tables do you find is a good compromise for smaller work like signs and lithophanes? Or should I just get a large machine. I would like your opinion on your favorite size cnc router table.
    Joescnc 4x4 R&P Router, Minimill, Minilathe, CNC Foamcutter, laser cutter, Vectric Aspire. http://makermasters.com, http://themakersguide.com
    Feb 2012
    IMO if you have the room and money, go big. You said one of the things you want to make is signs. A 4x8 sign wont fit on a 4x8 bed, but with a bigger bed a smaller project will fit. JMO
    Jul 2007
    168
    Bigger is usually better (IMO) why limit your self
    -Bigger table means larger lengths of material - Potentially less unusable scrap.
    -Cost savings of purchasing material in larger sizes.
    -Less time spent on cutting material down to size to make it fit your machine (some supply stores charge a cut charge).
    -More pieces out of one "material" setup, making multiple pieces at once.
    -Common size pieces of material (home stores) 2x4, 4x8. That being said, machine size preference would be a cutting area being able to accommodate those sizes.
    I've found that I save time by being able to lay a sheet down, fasten to table and start cutting. Plus I get more mileage from my raw material when using larger sizes.
    My 5'x5'x10" cutting area machine cuts acrylic, wood, aluminum, has a 4th axis and I want another machine to exclusively cut metal. The large Novakan or Tormach come to mind for size for metal. Novakan for the Z height since I want to move my 4th axis off of my current table.
    Feb 2010
    3447
    The only true limit is what you can afford.
    Sep 2011
    1183
    Quote Originally Posted by diyengineer View Post
    I agree 100%...
    Lou
    http://www.cnczone.com/forums/diy-cnc-router-table-machines/140832-cnc-software.html
    Mar 2004
    1806
    My 12"x12" was purpose built to:
    1. use in the house for PCB work
    2. As a test bed for software development.
    So I don't really want or need anything bigger:})
    Art
    AKA Country Bubba (Older Than Dirt)
    Feb 2012
    OK, you are not the center of the question.
    Quote Originally Posted by Bubba View Post
    Nobody asked what Bubba needs, wants or has. I'm:banana: building a 5'X10' and I can make a PCB board bigger than you can....naner naner.. The Pole question is the pole question. OBTH I can as well use my tool as " 2. As a test bed for software development." :banana::banana:
    May 2007
    428
    Quote Originally Posted by LouF View Post
    I agree 100%...
    Lou
    Usually the bigger, more costly, more opportunistic! :cheers:
    Dolphin CAD/CAM Support
    Sep 2011
    1183
    Wink
    Quote Originally Posted by Dolphin USA View Post
    Very true but for me being a hobbyist cost is a factor...
    May 2007
    428
    Very true. And it sure can be overwhelming when hunting!
    Feb 2012
    That's an understatement! you are hit that on the head.:cheers::cheers::cheers::cheers::cheers::chee rs::cheers::cheers::cheers:
    Aug 2012
    There is nothing about favorite for me its all depend on the requirement and affordability.
    I have now 8'×8' .
    Re: What size CNC Router do you like in your shop
    The medium size of table is more suitable for my work ~~ :cheers:
    ISweek(http://www.isweek.com/)- Industry sourcing & Wholesale industrial products
    Aug 2009
    655
    If you have a 4x5 available (my current size), then I personally would go for 2x4. That is the size of the vacuum zone I do 75% of the work on now. My next size would be 4x8 but that's a little big for a basement. Myself, I'm going to a 5x10 now. It's what we run in our other shop so I'm already taking jobs up to that size, now I just can do them in house and also be a back up machine for the other shop.
    Sent from my LG-D852 using Tapatalk
    In case anyone is wondering, I'm the twin of the other gfacer on cnczone...
    Jul 2009
    419
    I am about to start building my second, from 2x3 to 3x4.
    From what I see on advertisement sites is that the bigger a router gets, the lower the second hand value is, regardless of component price.
    Space seems to be a problem for the avarage second hand buyer.
    Now I need the bigger router for bread and butter but I will only build just a little bigger, so that I can do the stuff I know I want to be able to do.
    Sven
    http://www.puresven.com/?q=building-cnc-router
    Mar 2017
    164
    Quote Originally Posted by Randdy View Post
    I have now 8'×8' .
    Wow that's a wide X axis . Any pics? I don't know how a person could reach the middle ?
    Myself I'm wanting to build one around 4'-5' . If I had the room, a 4'x8'
  1. What size room for 4x4 CNC router?
    By TurnTex in forum DIY CNC Router Table Machines
    Last Post: 06-16-2013, 09:01 PM
  2. Best Shop Vac for CNC router?
    By jeffmorris in forum DIY CNC Router Table Machines
    Last Post: 07-26-2012, 10:54 AM
  3. Size of your shop or company
    By jweinhold in forum Community Club House
    Last Post: 12-03-2009, 09:48 PM
  4. Looking for CNC Router Shop
    By HigherClassAv in forum Uncategorised MetalWorking Machines
    Last Post: 09-30-2006, 07:27 PM
  5. Size of CNC Router to make
    By sdantonio in forum Open Source CNC Machine Designs
    Last Post: 11-16-2005, 09:00 PM
