I have some parts that have what I call a small 45 degree bevel on the edge, I think is called a Chamfer as well?
What tool would you use to do such a think? and where would I get one? This would be used a on sherline, btw.
Donald
Here is 1 place
http://www.mcmaster.com/param/asp/PS...824#ItemsTable
www.integratedmechanical.ca
what is small? if its a integral dimension of the part, as per DareBee, if its just for finish and to the remove the sharp edge/burr, use a good file
I've been using these drill point end mills with decent results.
http://www.wttool.com/c/10322200p
They same me a tool change on some projects too.
