603,409 active members*
2,891 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > What type of end mill is used for plastic?
Results 1 to 12 of 12
    Jun 2004
    201
    I want to cut acrylic sheet, and I was wondering if there is a special end mill for doing this so the edges of the plastic stay smooth and dont need to be polished after the cut.
    Mar 2003
    35494
    Onsrud makes bits for plastics. http://www.onsrud.com/index.html
    Vortex also has some. http://www.vortextool.com
    If you want a polished edge, you'll probably have to polich it, but it is possible to get a very smooth edge. The above tooling is generally for routers, btw.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Mar 2004
    37
    slot drill...
    Oct 2004
    107
    WHat spindles speed / material thicknees / cutter diameter.
    Machine ridgidity will have a marked effect of the surface appearance as well. You can see what you cant feel.
    2 flute straight cutters 3/8 or 1/2" I have had excelent results at 15-20 k spindle speeds, air blast and 100-200 ipm feeds. So acrylics are harder or softer which will also affect the cut IE cast / extruded sheet.
    To get a perfect edge a diamond cutter will works best, and a diamond edger will give you the best machined finish.
    Hope that helps.
    Mar 2003
    106
    Depending on the application, I have used router bits and Dremel bits. The Dremel bits work well in a variety of materials and they are inexpensive.
    Jan 2004
    3154
    Most plastics manufactures recomend using router type cutters.
    Jan 2007
    99
    If you have the rpm's, (6000+) Onsrud up spiral router bits are very good for edge finish. Plastic generally requires much more rake on the cutter, and the router bits fill that gap.
    -Greg
    "If Necessity is the Mother of Invention, then Who's the Father?"
    Jun 2007
    3738
    Cutter direction.
    I have found that conventional milling works better because the rubbing action burnishes the surface and helps to stop the cutter eating the chips.
    Use plenty of air to keep the chips clear.
    If there are many parts to do, cutter wear can become significant, so I use solid carbide.
    The coated cutters will give a better finish but are much more expensive, and they appear to have a more finely ground finish.
    Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
    Feb 2010
    230
    Onsrud 63-515 1/8" O-flute. 13,000 RPM at 120 ipm feedrate with 0.06" depth per pass. Not inexpensive but one of the best for all plastics.
    Regards, Carl
    Mar 2004
    368
    I tried every Onsrud cutter they recommended and they worked like *crap*.
    I followed their recommendations to a T, tried changing my cutting conditions and never got them to work worth a damn.
    I do not cut very thin stuff, nor do I do routing (although I cut parts out of acrylic on my VMC).
    In my experience, HSS seems to give a better finish than carbide. I was told HSS cutters hold a sharper edge. I have a piece of 1/2" acrylic block on my desk right now, I cut it out with a 1/2" eight flute finishing cutter (this one is carbide). The finish is not crystal clear, but it's damn close. It's a 1/2" thick block, 2" x 2" square. If I hold it up against my computer screen edge on (I cut out 4 sides), I can read text through it no problem - so it's pretty damn clear.
    That was around 30ipm, full depth, 1/4" on the width, shoulder cut, 6000rpm with coolant. Coolant makes ALL the difference. I 3D profile acrylic all day long - without coolant it's hazy with coolant I get a very clear (almost crystalline) finish.
    Nov 2005
    1468
    Acrylic? I cut lots of that with HSS two flute end mills- lets the chips get out. Air mist coolant- again to get the chips out.
    One note: Cast acrylic machines much better than extruded. I won't machine anything acrylic unless it's cast.
    You can smear the part with soap if you don't have air mist (thanks Geof)
    Hope this helps.
    I love deadlines- I like the whooshing sound they make as they fly by.
    Jan 2013
    Type of Bits to use
    - wrong place -
  1. G-Code to DXF
    By WayneHill in forum OpenSource Software
    Last Post: 08-09-2024, 08:56 PM
  2. Visual Basic Controller Project
    By dwwright in forum Visual Basic
    Last Post: 04-16-2016, 10:31 AM
  3. Ball end mill help
    By foamcutter in forum MetalWork Discussion
    Last Post: 07-21-2010, 06:59 PM
  4. What type of end mill do I need?
    By jderou in forum MetalWork Discussion
    Last Post: 09-03-2004, 08:59 PM
