603,896 active members*
5,808 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > What would this basic part look like? CNC XZ Lathe
Results 1 to 8 of 8
    Jul 2012
    14
    Hey guys,
    Very new to CNC and machining in fact. On a simple XZ plane lathe, could you please tell me what the outcome of this part would be. The grey background represents the part and the red(embarrassingly drawn in paint) represents the cut.
    What Im lost on is what does the four arcs(yes those are arcs) at radius of .250 on all four courners do? What would this look like on a part?
    My second question is, from what I understand on a XZ lathe what you do to one side of the part on a lathe you automatically do to all sides(because the part is constantly rotating.) Because of this, does one arc at one corner have to be programmed in and that is it and it would be the equivalent of the first picture I posted?
    Thank you for your time!
    Jul 2012
    14
    Bump!
    Feb 2009
    6028
    What it looks like?
    Depends on the diameter and length of the material.
    Aug 2010
    90
    Question it looks like......
    if its a blank, no thru hole etc.... good luck :rainfro::rainfro::rainfro: kelef
    after-thought :idea: draawing? well like.... no tolerances or other....
    Attached Files Attached Files
    Feb 2009
    6028
    If its 1/2 X 1/2 in length
    Aug 2010
    90
    going by scale, underthetyre, I think it's 3" dia x 1.75", but then photocopying a part to reverse engineer wouldn't be my first choice, a scale, a ruler? or even a vernier - kelef
    May 2004
    4519
    This post relates directly back to your other post at: http://www.cnczone.com/forums/genera...lathe_arc.html
    I want you to get a carrot and a knife. Hold the knife still against the carrot and rotate the carrot 360 degrees (just like a lathe would turn it). Watch the cutting of the knife. Now, cut about 1/4" off the end of the carrot so that you have a squared end. Hold the knife at about a 45 degree angle on the corner and rotate the carrot around 360 degrees again for the knife to cut off the corner. Watch the cutting action of the knife.
    Lathe turning is essentially the same thing. Many people have difficulty envisioning the concept of holding the tool stationary and moving the work piece to do the cutting. This is why many more machine shop workers are more comfortable on mills than they are on lathes.
    Aug 2010
    90
    a picture is worth a thousand words
    :idea: after :idea: after-thought just a graphical - :rainfro::rainfro::rainfro: kelef
  1. What machine is best to make a basic part like a drain cover?
    By brewvegas in forum Want To Buy...Need help!
    Last Post: 04-23-2012, 07:30 PM
  2. Basic milling on a lathe in XC
    By nikolaiownz in forum Mastercam
    Last Post: 04-03-2012, 06:30 PM
  3. basic programming TL2 lathe
    By lostpinky in forum Haas Mills
    Last Post: 09-13-2011, 08:18 PM
  4. Cutting a basic part in order
    By Delanoman in forum Mach Software (ArtSoft software)
    Last Post: 02-27-2009, 04:43 AM
